Old 09-21-2009, 06:07 PM   #1
larrybud
larrybud is on a distinguished road
Default Removal of 96 SOHC Cam Sprocket
I'm doing a head gasket change, and trying to remove the cam sprocket, but the bolt won't budge. It's not a left hand thread, is it?
Add to larrybud's Reputation
Rate the quality of this post and help larrybud reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
larrybud is offline   Reply With Quote
Old 09-21-2009, 06:13 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Removal of 96 SOHC Cam Sprocket
Lefty loosey, righty tighty.
A breaker bar and a length of pipe is something you might need.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 09-21-2009, 06:16 PM   #3
larrybud
Just wanted to make sure before I wail on it! Thx.
Old 09-21-2009, 06:47 PM   #4
jamie930
jamie930 is on a distinguished road
Just remove the whole cam from the head. Makes the head lighter to lift out, and then you dont have to crank the gear back on later
Seeing how you have a SOHC motor have the head pressure tested. The SOHC head like to crack for some reason. I think that they like to crack at the 3# cam journal. Someone correct me if I am wrong.
Add to jamie930's Reputation
Rate the quality of this post and help jamie930 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jamie930 is offline   Reply With Quote
Old 09-21-2009, 09:04 PM   #5
Abe95SC2
Abe95SC2 is on a distinguished road
Abe95SC2's Avatar
Checkered Flag Re: Removal of 96 SOHC Cam Sprocket
Second on getting the head checked. Some years of SOHC have a cracking tendancy. IIRC you can get a complete *new* SOHC head for less than $350
Add to Abe95SC2's Reputation
Rate the quality of this post and help Abe95SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Abe95SC2 is offline   Reply With Quote
Old 09-21-2009, 09:16 PM   #6
Squareback
Squareback's Avatar
2005 ION-2 Sedan
No, it's not reverse threaded, but it is torqued to 75 ft/lbs. There is a flat about midway down on the cam to hold it with a wrench...22mm if I remember right. It'll come out.
Certified Saturn Technician
Old 09-21-2009, 09:21 PM   #7
Squareback
Squareback's Avatar
2005 ION-2 Sedan
You're wrong. They crack on the #4 cam journal, and if the OP doesn't have a thick milksahke mess in his overflow bottle, then the head isn't cracked. Sending it out would be a waste of money and time. There's also no need to take the cam out when removing the head. The head isn't very heavy, and neither is the cam, or the sprocket. I remove the head with the intake still attached, gives you something nice and solid to grab onto.
Old 09-21-2009, 09:51 PM   #8
V9exp
V9exp is on a distinguished road
2001 SC1
Its a standard thread, lefty loosy righty tighty. and yes there is a wrench flat (7/8) just past your first 2 or 4 lifters 74ft/lbs. I highly recomend having 2 people for the job when breaking it loose with a cheater bar. make sure your crank is 90 degrees past TDC and your camshaft its at dead on TDC when reinstalling your head. this ensures no damage to your valves. when accomplished just counter rotate your crank back to TDC and install timing components.
Add to V9exp's Reputation
Rate the quality of this post and help V9exp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
V9exp is offline   Reply With Quote
Old 09-21-2009, 10:46 PM   #9
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Two people?? Sounds like a bit much. I've never needed more than a 15mm wrench to break the cam bolt free.
95 SL1 - Installing SOHC auto PCM in SOHC manual RPM rev limit removal / change 3danh S-Series Tech 34 07-21-2017 04:31 AM
Need pic of cam sprocket retention tool and valve spring removal tool sr20fd3st S-Series General 2 07-13-2009 10:41 PM
95 SC2 Cam Sprocket iss407 S-Series Tech 2 01-12-2008 04:39 PM
Cam Sprocket glewisr Mods and Performance 2 11-13-2003 11:05 PM
Camshaft sprocket removal '95 DOHC. Abe95SC2 Miscellaneous Tech 5 03-31-2002 09:04 PM
