Old 06-08-2009, 01:52 PM   #1
HAS82
HAS82 is on a distinguished road
Default Body Control Module (BCM)
Does it have anything to do with air conditioner??
Add to HAS82's Reputation
Rate the quality of this post and help HAS82 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HAS82 is offline   Reply With Quote
Old 06-08-2009, 03:20 PM   #2
Default Re: Body Control Module (BCM)
Only as a conduit to monitor a/c signals for diagnostics purposes and to pass control signals through to the ECM. The ECM needs a/c signals only to alter engine rpm from compressor load otherwise the HVAC control panel is the main control for turning on the a/c. If you are having a/c issues the bcm isn't likely the cause or failure for the a/c system to operate. Most members posting about bcm issues write about random lights turning on/off, horn beeping, and disabling the engine from running, not about interfering with a/c operation.
2006 Vue Bcm (body Control Module) Failure VUESBROTHERS Vue General 35 08-25-2016 12:27 PM
BCM (body control module) question stranger666 L-Series Tech 5 09-11-2009 09:51 AM
Body Control Module (BCM) problems intrepid2006 General Saturn Discussion 7 07-11-2009 07:19 PM
Body Control Module Mark S. L-Series Tech 3 02-13-2009 09:52 AM
Body Control Module BCM Replacement DonF Vue General 7 12-21-2004 08:52 PM
