Old 05-02-2009, 06:01 PM   #1
trash
trash is on a distinguished road
Default Removing rear brake drum '02 sc2
Hi guys,
I broke a stud today trying to remove a rusted lug nut. How do you remove the brake drum to replace the stud? It appears that the drum is friction fitted onto the hub/center piece, but no amount of persuasion is letting me remove it. The drum spins freely as I don't have the parking brake on. There is no side to side movement at all which makes me think I'm missing something.
Thanks
Ron
Add to trash's Reputation
Rate the quality of this post and help trash reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
trash is offline   Reply With Quote
Old 05-02-2009, 06:15 PM   #2
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
Default Re: Removing rear brake drum '02 sc2
It's rusted on, get a can of PB blaster and/or a gear puller.
Good Luck!
Rick
2005 ION 2 5 spd 202,155 miles
2001 SL1 Auto 298,252 miles
1997 Sl1 Auto 163,266 miles
Add to rickystarshine's Reputation
Rate the quality of this post and help rickystarshine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rickystarshine is offline   Reply With Quote
Old 05-02-2009, 06:16 PM   #3
If you broke a stud due to rust then the drum is for sure rusted to the hub. It normally, IE new not rusted, should slip on and off.
Use of a hammer hitting between the studs should break the rust free. You will still need to fight it off. A flat screw driver betwwen the drum and the backing plate to pry while tapping hitting the drum should get it off.
Add to ssicarman's Reputation
Removing rear brake drum on '04 Vue tjpengineer Vue Tech 8 12-08-2012 12:24 AM
Rear Drum Brake Question Critik S-Series General 3 04-02-2008 10:56 PM
rear brake drum squeak! SL1commuter S-Series Tech 9 04-08-2007 10:14 AM
Rear Brake Drum Noise hipster35 S-Series Tech 5 02-22-2007 08:51 AM
rear drum brake replacement unkle bik S-Series Tech 4 10-27-2006 02:23 PM
