Old 04-24-2009, 03:26 AM   #1
xtchc1978
xtchc1978 is on a distinguished road
2001 SL2
Default 1999 sl2 with 1997 sl2 engine need help
I picked up a 1999 sc2 with a low mileage engine out of a 1997. Problem the 97 engine does not have the right manifold for the air pump and it's throwing a code. The car runs great though. Can't have any codes in my state or it can't be registered, won't pass emissions. Can't see a way to rig the air pump to the manifold in it and the bolt pattern is different then the 99 manifold. Was wondering if I can just get a 97 dohc auto pcm or am I stuck finding a way to drill out the manifold, is the harness the same? Are there non air pump 99 pcmís that will interchange? Any other problems changing the 99 pcm to a 97? Any other reasonable options?
Add to xtchc1978's Reputation
Rate the quality of this post and help xtchc1978 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xtchc1978 is offline   Reply With Quote
Old 04-24-2009, 08:41 AM   #2
rc1488
rc1488's Avatar
Default Re: 1999 sl2 with 1997 sl2 engine need help
There are non AIR '99 PCM's....but RARE. IIRC you can use a '98 PCM and that should work just fine.
Add to rc1488's Reputation
Old 04-25-2009, 09:08 AM   #3
BarnOwl
BarnOwl's Avatar
You might try contacting www.saturnautosalvage.com. They seem to be able to get some things done with PCMs others can't. They might be willing to swap you.
Add to BarnOwl's Reputation
Old 04-26-2009, 05:19 AM   #4
xtchc1978
2001 SL2
Thanks, I have a line on a 98 dohc auto pcm locally, worth a shot.
Old 05-06-2009, 04:32 AM   #5
xtchc1978
2001 SL2
Got the 1998 pcm today and hooked it up. Direct fit, no codes, started right up, so far so good. Pretty much confirms 1997 engine into a 1999 equals a 1998 pcm if you donít want to throw any codes, if anyone didn't know that. Now the 99 sc2 is just a few minor parts away from completion, got out of this one pretty cheap
Old 05-06-2009, 12:00 PM   #6
Greg1
Greg1's Avatar
1997 SW2
They don't do a visible inspection as part of the test? Here in California a 99 would fail for not having the pump..
97 SW2 5-Sp 273k -mine
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-06-2009, 03:01 PM   #7
rc1488
rc1488's Avatar
California is different than manyyy other states. Her in NY my neighbor passed inspection with NO cat.
Old 05-06-2009, 03:05 PM   #8
fib4
fib4 is on a distinguished road
No worries of passing or failing in tennessee as there is no inspection here.
Add to fib4's Reputation
Rate the quality of this post and help fib4 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fib4 is offline   Reply With Quote
Old 05-06-2009, 03:38 PM   #9
Greg1
Greg1's Avatar
1997 SW2
Yes indeed California is strict. They even pressure test the fuel tank on OBD I cars now. I was curious about testing in Connecticut and found this:
If your vehicle has any of these safety problems it will not be tested:
Excessive brake fluid leaks or any leaking fluids
Tires, wheels, or other unsafe conditions that make a vehicle unsafe to operate on the dynamometer including studded tires.
Emissions equipment tampering
Old 05-06-2009, 04:03 PM   #10
Low Saturn
Low Saturn's Avatar
2000 SC2
The 1999 SC2 I used t have didnt have an air pump and it passed. Just needs a Federal Emissions sticker on the radiator support.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 05-08-2009, 03:11 AM   #11
xtchc1978
2001 SL2
The thing is no codes no problem, they will never check the air pump. They would not know if there was one in there to begin with. 98 no air pump, 99 air pump, and then the 99 non air pump exceptions, they would have no way of knowing. We now have independently run emissions testing centers not state facilities. They do not do dynamometer testing unless the car is older then 95. They check under the car, hook up the computer and that is it, no codes and you are on your way. Now if it were a missing cat then yeah but not an air pump.
1999 SL2 1.9 DOHC engine specs losethetail S-Series Tech 8 08-22-2013 12:33 PM
1999 SL2: Engine won't Start/Won't Crank LoganSan S-Series General 26 12-20-2012 02:25 AM
1997 SL2 engine problem 2timesatowner Introductions & Greetings 2 05-15-2009 05:02 PM
Flooding engine 1999 SL2 janetommey S-Series Tech 6 01-19-2008 03:53 PM
1999 SL2 Engine Swap balgemab S-Series General 1 07-09-2006 03:13 AM
