Old 11-06-2008, 03:32 PM   #1
siliconvalley
siliconvalley is on a distinguished road
Default valve stem seal removal tool
I saw this tool at Harborfreight:
http://www.harborfreight.com/cpi/cta...emnumber=97975
Would it be suitable to remove the seal in our DOHC or SOHC cams?
Add to siliconvalley's Reputation
Rate the quality of this post and help siliconvalley reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
siliconvalley is offline   Reply With Quote
Old 11-06-2008, 04:30 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: valve stem seal removal tool
The one I use looks like a giant "C" clamp.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 11-06-2008, 04:38 PM   #3
OnDaGround
OnDaGround's Avatar
1993 SC2
^^ the one that weighs like 10 pounds (over exaggerating) and has the pointed tip and the hole on the other side?
Saturnless...
Old 11-06-2008, 04:43 PM   #4
Low Saturn
Low Saturn's Avatar
2000 SC2
No. Not even close.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 11-06-2008, 04:44 PM   #5
OnDaGround
OnDaGround's Avatar
1993 SC2
lol... I guess I'll have to take a picture of it with my phone one day.
Saturnless...
Old 11-06-2008, 07:53 PM   #6
Canyon
Canyon has a spectacular aura aboutCanyon has a spectacular aura about
1999 SL1
Siliconvalley: The tool you pointed to is to remove valve guide springs, not the valve guide seals. Check my pics for one to remove valve guide seals. It also comes in handy to disassemble lifters. I have a pic of the tool I use to remove valve guide springs. Mine mounts to the top of the head so you don't have to remove the head from the block to remove the valve springs or valve guide seals.
I don't use these tools often as I usually send the head out to have it reworked.
What is is that you are trying to do?
Add to Canyon's Reputation
Rate the quality of this post and help Canyon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Canyon is offline   Reply With Quote
Old 11-07-2008, 01:31 PM   #7
siliconvalley
Canyon, thanks for pointing me to your pics. Now I know the HF tool can't be used to remove the seals.
What am I trying to do? I am thinking of replacing the valve seals cuz my combustion chamber is very dirty(the other day, I took the plugs out and look down at the pistons. They are covered with a thick layer of black carbon). It needs a new set of rings too.
Need pic of cam sprocket retention tool and valve spring removal tool sr20fd3st S-Series General 2 07-13-2009 10:41 PM
Valve Stem Seal Replacement martyrpowell S-Series Tech 24 06-23-2009 09:57 AM
Valve spring Removal tool-Head on Car 91SL2 Classifieds 0 09-11-2005 02:44 PM
can't get valve keeper off stem eljefino S-Series Tech 4 07-01-2004 04:31 PM
valve Stem Seals 91SL2 S-Series Tech 5 11-15-2000 08:58 PM
