Old 07-22-2008, 09:38 PM   #1
MikeNW
MikeNW's Avatar
1997 SL
Default Wheel bearing source
I think I need a wheel bearing.
From my recent clutch experience, I want OEM parts.
Anybody have any recommendations? Does Rock Auto have OEM parts? Or should I order from a Saturn on-line source?
Also, would a bottle jack and frame be adequate to press in the new one, that way I could do it at home. Or do you need a larger press.
Thanks!
08 Burgman 400
Add to MikeNW's Reputation
Old 07-22-2008, 09:48 PM   #2
Squareback
Squareback is a jewel in the roughSquareback is a jewel in the roughSquareback is a jewel in the roughSquareback is a jewel in the rough
Squareback's Avatar
2005 ION-2 Sedan
Default Re: Wheel bearing source
Bottle jack definitely isn't gonna cut it. To save money you can remove the spindles yourself and take them somewhere to have the bearings pressed. Unless you have a shop press in your garage, don't attempt to do this yourself, you will destroy the bearing. The bearing doesn't necessarily need to be Saturn, a good quality BCA/National or Timken bearing is more than adequate. I used the Timken when I did the front bearings in my sister's '97 SL2 and I got the kit with the new hubs also. No problems yet over a year later and about 15K miles.
Certified Saturn Technician
Add to Squareback's Reputation
Rate the quality of this post and help Squareback reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Squareback is offline   Reply With Quote
Old 07-22-2008, 10:15 PM   #3
MikeNW
MikeNW's Avatar
1997 SL
Thanks
Bummer though. I plan to pull out the whole strut so I don't disturb the alignment, a little harder to tote around town.
08 Burgman 400
Old 07-22-2008, 10:19 PM   #4
rc1488
rc1488 has a spectacular aura aboutrc1488 has a spectacular aura about
rc1488's Avatar
Pull the spindle as youll regret it later
Also there isnt much play in the stock struts regarding camber. Ive done all my cars except my '97 (after market struts) by eye with no issues.
Current: 95 SC2 Man 97 SL2 Auto 98 SL1 Auto 01 SL1 Man 02 SL1 Man
Past: 94 SL2 Man 95 SL2 Man 95 SL2 Man 96 SL2 Auto 97 SL2 Man 98 SL2 Auto 99 SL2 Auto
2010 SCCA Mohud Street Championship-2nd Place
Add to rc1488's Reputation
Rate the quality of this post and help rc1488 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rc1488 is offline   Reply With Quote
Old 07-22-2008, 10:26 PM   #5
MikeNW
MikeNW's Avatar
1997 SL
Hmmmm
Saturn parts.net $97.34 each
Rock Auto
Timken $27.79
BCA $38.79
Quite a disparity!
So, would you go with Timken or BCA (or doesn't it matter)?
I understand ya might as well do both front bearings......
08 Burgman 400
Old 07-22-2008, 11:58 PM   #6
I think BCA
Old 07-23-2008, 01:20 AM   #7
madpogue
1996 SW2
Mark the location of the strut relative to the knuckle with a paint pen. This should get the camber close enough. Mark at top and bottom, to be sure.
Add to madpogue's Reputation
Old 07-23-2008, 03:39 AM   #8
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Why get it close enough when you can get it dead on? He's doing it the correct way to ensure he won't change any alignment specs. Not to mention how much easier it is to undo the 3 strut mounting nuts as opposed to the strut to spindle bolts. I always take out the strut/spindle as an assembly, press the new bearing(s) in and reassemble as a unit. It's simply easier, and no chance of needing an alignment when you're done. Not really any more difficult to bring to a shop to have it pressed, just a little heavier is all. I used the Timken bearings myself, but wouldn't hesitate to use the BCA/National either.
Why would he regret it later? Because he doesn't have to shell out $70 to get his car aligned afterwards?
Old 07-23-2008, 10:53 AM   #9
madpogue
1996 SW2
It wouldn't be dead-on if s/he (or any PO) has ever had the caster set by expanding the three top-mount stud holes. S/he'd be in the very same boat wrt. the alignment (either mark and get it "close enough" or re-align).
But yeah, we're talking 30-ish ft-lb vs. 100+ for the fasteners. We all have our strengths and weaknesses; some folks are stronger at wrestling high-torque fasteners, and others stronger at lifting/carrying more weight. Six of one.....
Old 07-23-2008, 11:15 AM   #10
MikeNW
MikeNW's Avatar
1997 SL
I had the car aligned once so far. From taking off the left strut recently, the mounting holes are not oversized.
Plus, I used a silver magic marker and traced around the washers, on the strut tower, before I removed the strut. A small error there doesn't matter much. A small error on the "knuckle" bolts matters more, due to the geometry of the suspension.
As my HS algebra teacher would say, I would rather "let sleeping dogs lie" (and not touch the two large bolts and nuts).
08 Burgman 400
Old 07-23-2008, 11:21 AM   #11
92SL1Mann
92SL1Mann is on a distinguished road
1992 SL1
1996 SC2
ha the Timken ball bearings themselves are made down the road in St Thomas! When I did mine i didnt want to wait for rock auto so i went to the parts store. they were in between OEM and rock cost wise. think they were TRS or something....12,000km ish on them so far still good
1992 SL1, 376,000Kms
1996 SC2, 243,000Kms
Add to 92SL1Mann's Reputation
Rate the quality of this post and help 92SL1Mann reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
92SL1Mann is offline   Reply With Quote
Old 07-23-2008, 11:42 AM   #12
Low Saturn
Low Saturn's Avatar
2000 SC2
I just go to the local auto parts store and get what they have. In fact I'm dropping off some knuckle/hub assemblies tomorrow after work for some new bearings. $20 each for the bearings and $40 for the set to press them.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
wheel bearing help lansing78 L-Series Tech 2 04-02-2014 12:16 AM
Wheel Bearing seems OK 98Saturn S-Series Tech 7 06-22-2009 03:54 PM
need help for wheel bearing stankus4 S-Series Tech 12 03-05-2008 03:54 AM
Please help-wheel bearing or what? dodger S-Series General 12 07-09-2006 09:45 AM
wheel bearing lodingi Vue General 4 06-07-2005 10:07 PM
