Old 06-25-2008, 11:02 PM   #1
TrojanMan
TrojanMan is on a distinguished road
Default 2002 Sl1 P0507
Same ole story, check engine light came on, had autozone hook it up to check errors and got cyl #1 misfire and high idle P0507. I understand that this has something to do with a vacuum condition. Most of what i have read suggest a new gasket on the intake manifold.
I would appreciate the following: Common causes of this error and what steps i can take to determine exactly what is causing it.
Second, will driving the vehicle in this condition cause any permanent damage or cause the car to fail. I'm getting ready to take a long trip with this car and dont want to be stuck on the side of the road.
Thanks!
TM
Add to TrojanMan's Reputation
Rate the quality of this post and help TrojanMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TrojanMan is offline   Reply With Quote
Old 06-25-2008, 11:13 PM   #2
Default Re: 2002 Sl1 P0507
Welcome to the Board.
You have read up on it so you know the check is to spray intake cleaner or brake clean at the intake gasket area, engine running. The idle will change. This will confirm what the codes have told. 99% chance that it is the gasket folded in.
Best to replace the gasket before you go on the trip but it should not do serious damage if left. I have seen cars barely run because of this but it is never something that should be left. You have a vacuum leak at the intake. This allows unfiltered air into the engine and sets undesirable PCM adaptives due to the leak.
Add to ssicarman's Reputation
Old 06-26-2008, 11:24 AM   #3
If it's the initial cause of the gasket failure you're looking for, it's on the car's title. The fact that it's a 2002 SL1, a third-generation SOHC. During that time, there was a robot at the factory in Spring Hill with a serious drinking problem, that installed several of the gaskets with a crease in them. Somehow, they still managed to hold, but it was only a matter of time until they would fail (right about now, evidently).
Add to madpogue's Reputation
97 SL1 P0507 ugg... Philhawk02 S-Series Tech 6 04-16-2011 08:34 PM
P0507 and P0301 on 2002 SL brianfromoregon S-Series General 10 09-30-2009 07:03 PM
I just got a P0507 Frankd1 S-Series Tech 11 06-05-2009 10:16 AM
1999 SL1 throwing codes P0301, P0405, P0507 justinchristie S-Series Tech 2 06-05-2008 05:54 AM
2002 Automatic SL1 to 2001 5 speed SL1 trans Saturntrip S-Series Tech 4 01-30-2008 09:46 PM
