Old 06-04-2008, 10:43 PM   #1
justinchristie
justinchristie is on a distinguished road
justinchristie's Avatar
1999 SW1
1999 SL1
Default 1999 SL1 throwing codes P0301, P0405, P0507
Ok,
I've had this car a week, and it has been throwing the P0301, P0405, P0507 codes. It's a 1999 SL1 SOHC, withe 103,600kms. :S
From a little bit of searching on the forum, it looks like this is the intake gasket folding issue that many have encountered.
Just to give you some symptoms:
1. the car, at idle in park, seems to idle "ok", maybe a bit high at 1000-1100 rpm
2. when i put the car in drive, and apply the brakes, like when you come to a stop, the car has very low idle, and it starts to feel like it kicks - i'm guessing the idle is like 500-700rpm, or maybe lower. almost seems like it will stall
3. when i spray carb cleaner near the 1st cylinder (near the power steering reservoir) the rpms drop. The car is in park, so the rpms are like 1000-1100rpm, then it drops to 700-800rpm when i spray the carb cleaner
4. Other than those problem listed above, the car runs great on the highway/city and has no hesitation/problems otherwise
So, is this a clear-cut issue with the intake gasket? or is it battery related? I'm tending to think gasket with the rpm change due to the carb spray.
From what I have researched, it looks like it is some $$$ towards a gasket, 2-3 hours of wrench time, and a 6-pack of beer.
How much is the felpro gasket anyways?
What's your opinion?
Add to justinchristie's Reputation
Rate the quality of this post and help justinchristie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
justinchristie is offline   Reply With Quote
Old 06-04-2008, 11:27 PM   #2
Default Re: 1999 SL1 throwing codes P0301, P0405, P0507
Sounds like you need to go buy the beer. You need a gasket. RockAuto to find the price.
Old 06-05-2008, 05:54 AM   #3
BarnOwl
BarnOwl's Avatar
You're going to have to drain the coolant to do that gasket. You might as well replace the ECTS while you're at it, if you haven't already. I've had good luck with the Airtex sensor from rockauto.
Add to BarnOwl's Reputation
P0507 and P0301 on 2002 SL brianfromoregon S-Series General 10 09-30-2009 07:03 PM
P0301 and P0507 boojunji S-Series Tech 11 06-27-2009 12:10 AM
P0405 and P0341 codes come on and then go off randomly LotusLord S-Series Tech 5 04-02-2008 03:52 PM
New ECTS, now throwing codes at me!! Tempsho S-Series Tech 27 03-02-2006 07:02 PM
Throwing codes 23 35 45 JS593 S-Series General 9 01-05-2006 12:11 AM
