Old 01-06-2008, 05:34 PM   #1
Wabell
Wabell is on a distinguished road
Dizzy HI all New used saturn owner here
Hi all,
i have recently bought a 1996 saturn (ZE18) 2d sedan im not sure what series this is but compared to pics of others its an s series. anywho its a 5 speed 1.9 Ive been haveing a few probs hope someone can help. First off is the temp gauge doesent work most of the time although sometimes it jumps to half and back down sometimes its just on 1/4 whats wrong? second my motor likes to rev itself up when in idle or in nuetral between shifting gears always comes back down though. and third is that both my windows (electric) when trying to roll them up the front drops and window gets stuck, If i hold the front up then hit the switch i can get it rolled up with some effort. I took the door apart today and i cannot see anything wrong with track can someone help me with this or tell me how to find replacement track and or guides thanks abunch, Bill
Add to Wabell's Reputation
Rate the quality of this post and help Wabell reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wabell is offline   Reply With Quote
Old 01-06-2008, 06:06 PM   #2
rc1488
rc1488's Avatar
Default Re: HI all New used saturn owner here
Originally Posted by Wabell View Post
Hi all,
heyy welcome! sounds like you have a SC model based on the 2 doors. As with every new member greetings, change your ECTS! there are instructions in the How-to section as a sticky. you cant miss it.
as to the window issue, search the forum and the how-to page for help with the window. sounds like something happened to the track bc it doesnt rise straight.
oh and always post your vitals, aka year, milage, auto/man..etc.
check your oil once a week!
Add to rc1488's Reputation
Old 01-06-2008, 06:24 PM   #3
Wabell
Happy Re: HI all New used saturn owner here
thanks for quick reply, its a 96 with 183k miles will change the etcs tommorow. I check oil every fill up(every week) useing 1/2 quart to 1 quart per 350-450 miles hope this is normal. where is the how to section?? this sight is great so far thanks again, Bill
Old 01-06-2008, 06:47 PM   #4
rc1488
rc1488's Avatar
this site is AWESOME! it sounds normal for saturn oil burning. there are different remedies you can try to lower that including a MMO piston soak (again in the how-to library) which many have found helpful. i have not done it tho so i cant speak from experience. auto? manual?
http://www.saturnfans.com/forums/forumdisplay.php?f=26
Old 01-06-2008, 07:17 PM   #5
eljefino
eljefino's Avatar
1995 SW1
Is there a tab on the back of the glass? Had an old k-car once that this tab held the rear of the window in. Had to firmly pull it inwards, then set the tab and release.
You have classic ECTS failure, to repeat a previous poster. Change it and you will be blessed with a perfect car, for the price of 3 gallons of gas!
Add to eljefino's Reputation
Old 01-06-2008, 07:18 PM   #6
MotorMan
MotorMan is on a distinguished road
I had an s-10 pickup with a window problem like yours.
There was a plastic tab that ran in the track that attached to the window.
When the window would slip out of the tab, the window would go crooked.
Add to MotorMan's Reputation
Rate the quality of this post and help MotorMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MotorMan is offline   Reply With Quote
Old 01-06-2008, 08:54 PM   #7
Wabell
i just found out my car is a sc1 1996 1.9l 5 speed with 183k miles lol just found out the sc1 part my windows have what is called a window regulator which consists of what looks like a big folding x has one track fixed too the window at the bottom by sash nuts the window then has roller type glides that slide in the track as the window goes up or down only the one to the front doesnt slide enough or fast enough im not sure which ive looked for replacementparts even found how to change it out in the diy section of this site but ive looked for hrs now and cannot find the parts to buy for 1996 sc1 2 dr i can find some for 2000 and up are these compatible ones? thanks for the info so far
Old 01-07-2008, 06:42 AM   #8
BarnOwl
BarnOwl's Avatar
Go to www.car-part.com. That's a web site that will search salvage yards in your area for parts. Search for a window motor. It should come with the regulator.
Add to BarnOwl's Reputation
Old 01-08-2008, 04:14 PM   #9
Wabell
hey again, you guys are awesome changed the etcs and car running great! thanks. i have a new question though i have a very very slight lifter tapping sound only heard with the hood open is this a bad sign?? i owned a ford escort 5 speed that sounded they same way but it was typical of fords or so I was told I never had a problem with the escort so hopeing my saturn is fine.
1996 SC1 1.9 5 speed 183k getting 37 38 mpg
Old 01-08-2008, 08:02 PM   #10
virnin
virnin is on a distinguished road
virnin's Avatar
hey again, you guys are awesome changed the etcs and car running great! thanks. i have a new question though i have a very very slight lifter tapping sound only heard with the hood open is this a bad sign?? i owned a ford escort 5 speed that sounded they same way but it was typical of fords or so I was told I never had a problem with the escort so hoping my saturn is fine.
As several recent threads have turned up, check your plug wires. Several people have fixed what they thought was a noisy lifter with new wires. Unless you check when it's good and dark out, you might have a touch time finding that little spark leak that's making the ticking sound. And if your wires are the factory originals, your car has been on borrowed time for a lot of miles!
Add to virnin's Reputation
Rate the quality of this post and help virnin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
virnin is offline   Reply With Quote
Old 01-09-2008, 03:20 AM   #11
yogi1200
yogi1200 is on a distinguished road
yogi1200's Avatar
1993 SC1
2004 ION-3 Sedan
Maybe some lithium grease on the window piece that is slow!? Welcome to the site.
Add to yogi1200's Reputation
Rate the quality of this post and help yogi1200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
yogi1200 is offline   Reply With Quote
New Saturn owner from WI BAD LS1 Introductions & Greetings 3 11-11-2009 11:00 AM
New saturn owner Hybrix Introductions & Greetings 4 08-25-2009 01:32 PM
New Saturn Owner SpeedDemon L-Series General 4 09-06-2005 08:16 PM
new saturn owner gaddy 98 SC2 S-Series General 11 10-17-2003 12:07 PM
New Saturn Owner BRI'S98SL-2 Mods and Performance 4 04-17-2002 04:00 PM
