Old 12-14-2007, 05:21 PM   #1
DMVue
DMVue is on a distinguished road
DMVue's Avatar
Default 3.5 l coolant temp sensor
Anyone know how to check it to see if its working properly?
Add to DMVue's Reputation
Rate the quality of this post and help DMVue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DMVue is offline   Reply With Quote
Old 12-14-2007, 07:59 PM   #2
Default Re: 3.5 l coolant temp sensor
Yes, if you know where its located and can use a multimeter then copy/print the data table from post #6 ; http://www.saturnfans.com/forums/sho...coolant+sensor. If the engine starts up, runs a slight high idle during warm-up and gradually returns the rpm's back to a normal idle within 10-15 minutes of driving then the coolant sensor is operating properly. You can always replace it if its inexpensive.
Old 12-14-2007, 09:29 PM   #3
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
What makes you think it's not working properly?
Most of them hover around 3/8's and show little movement. There is variations in temperature that I monitor with my ScanGuageII, that don't show on the temp guage.
Add to BobbyP's Reputation
Old 12-14-2007, 11:17 PM   #4
DMVue
DMVue's Avatar
Well for one, the gas mileage sucks big time 15.5 -16 50/50 city hwy driving and for two, the temp gauge reads at 1/4 mark when the engine is cold. I know some will say that I need to check the gauge but the sensor is easier to trouble shoot. I have had 2 SES lights come on for a split second but I guess it was not enough for Autozone to pull on their code reader. I am going Tomarrow to have a shop check it with a Tech II. Its probably just all in my head that my mpg is bad. Its been about 20-35 degrees F here in MI. I have been running my vents one notch off the floor and I have been babying the gas. The VUE has 90k miles on it with fresh trans fluid, original plugs and original O2 sensors. The Oil change that I have was accidentally done with 5w30, but not by me(don't know how someone could screw that up seeing as it says 5w20 RIGHT ON THE CAP . wheel allignment is perfect and tires are filled to 32 psi with nitrogen. Anyone see why I should not be getting 20+ mpg? Am I overlooking anything? I do know my way around a car pretty well so I am open to checking anything myself. sorry for the long post.
Dan in MI
Old 12-15-2007, 01:01 AM   #5
Tire pressure should be 35 PSI.
Won't make a big difference on the MPG but every little bit helps.
Add to ssicarman's Reputation
Old 12-15-2007, 01:18 AM   #6
Vue&SL1
Vue&SL1 is on a distinguished road
Vue&SL1's Avatar
Dan in MI
15.5-16 mpg seems low. Where I live we have been a deep freeze for a couple of weeks now (-10F overnight and a highs consistently around +15F during the day) and I just filled up today and got 20.5 with 100% city driving. On my last tank I got 22.3 mpg with mostly city driving. Of course, the only way I can get even the 20.5 is to baby the throttle and keep it under 2,000 rpms always. When I first got the VUE 3.5 I thought it was a lot of fun to keep my foot in it (which it was) and I got numbers similar to yours.
2000 SL
2006 VUE 3.5
Add to Vue&SL1's Reputation
Rate the quality of this post and help Vue&SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Vue&SL1 is offline   Reply With Quote
Old 12-15-2007, 09:17 AM   #7
kodak_jack
kodak_jack is on a distinguished road
kodak_jack's Avatar
Dan in MI
Your problem is temperature. Any vehicle will drop when the temps go down. I get around 25MPG in warm weather, but drop to about 20 in the cold. I'm also convinced that as gas prices go up, my mileage is going down. The quality of what you're getting varies a lot - without your driving style changing.
Add to kodak_jack's Reputation
Rate the quality of this post and help kodak_jack reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kodak_jack is offline   Reply With Quote
Coolant temp sensor? 3500srw S-Series Tech 8 06-26-2008 11:45 PM
coolant temp sensor or what??? RMracing125 S-Series Tech 2 02-19-2007 07:31 AM
coolant temp sensor danbandMN S-Series Tech 1 11-24-2005 12:29 AM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
where is the coolant temp sensor buddyc S-Series Tech 2 08-06-2003 06:18 PM
