Old 11-11-2007, 11:30 PM   #1
casterman
casterman is on a distinguished road
Default 97 SL2 -- what should the compression be?
what should the compression be on an engine with 120K miles?
Add to casterman's Reputation
Rate the quality of this post and help casterman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
casterman is offline   Reply With Quote
Old 11-11-2007, 11:49 PM   #2
rc1488
rc1488's Avatar
Default Re: 97 SL2 -- what should the compression be?
Up near 150 psi or higher
Add to rc1488's Reputation
Old 11-12-2007, 06:12 PM   #3
AndyB
AndyB is on a distinguished road
1995 SW2
I have a 95 sw2 with ~145k. I tested mine a month ago and each cylinder showed about 225 psi. BTW, the reason I tested mine is because it has recently gone from using a quart of oil every 1500 miles to a quart every 500 miles
Add to AndyB's Reputation
Rate the quality of this post and help AndyB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AndyB is offline   Reply With Quote
Old 11-13-2007, 07:30 AM   #4
BarnOwl
BarnOwl's Avatar
In general, you aren't looking so much for a specific number but, whether all cylinders are in the same general area. If you have on cylinder that reads a lot different than the others, you have a problem.
Add to BarnOwl's Reputation
Old 11-13-2007, 02:22 PM   #5
eljefino
eljefino's Avatar
1995 SW1
And if you do a leakdown test you'll often draw the wrong conclusion on a saturn, as to whether it needs rings or not.
Do what barnowl says.
Add to eljefino's Reputation
Old 11-13-2007, 03:09 PM   #6
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
I think between 180 and 210 is what healthy saturn engines test at
Add to plastic torpedo's Reputation
Rate the quality of this post and help plastic torpedo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plastic torpedo is offline   Reply With Quote
Old 11-13-2007, 04:41 PM   #7
teenytaurus
teenytaurus is on a distinguished road
Both the Haynes and Chilton say 180-210, but when brought to operating temperature (pull the plugs on a hot engine??). One Saturn tech told me 180-210 was correct, although 160 and even (within about 5 psi?) was good on a higher mileage engine. Wouldn't doing a compression test cold give you lower numbers than hot? I'm a bit confused there. I've got 205-210 on mine cold, and almost 200K on it.
`Sue`
It ain't done until it's done right
'94 SL2, auto, holding my breath until the 200K mark :-)
Add to teenytaurus's Reputation
Rate the quality of this post and help teenytaurus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
teenytaurus is offline   Reply With Quote
Old 11-13-2007, 04:57 PM   #8
1999greenSL2
1999greenSL2 is on a distinguished road
1999greenSL2's Avatar
I think heat = expansion, so less compression when cold sounds right to me.
Add to 1999greenSL2's Reputation
Rate the quality of this post and help 1999greenSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1999greenSL2 is offline   Reply With Quote
Old 11-13-2007, 05:16 PM   #9
teenytaurus
I thought so, too, so was a little shocked I got such high compression on such a high mileage engine (that was abused by the previous owner). A lot of carbon causing higher readings, or am I just one lucky lady? lol
`Sue`
Compression check 1999 SL2 SBXLI93 S-Series Tech 6 05-18-2009 04:03 PM
96 Saturn SL2 low compression groingo S-Series General 2 04-21-2009 10:49 AM
What to do with 96 SL2? Low compression.... almies S-Series General 3 06-12-2008 02:52 PM
Compression Test on my 96 SL2 LoveMySaturn S-Series General 3 03-06-2004 10:16 PM
96 SL2 COmpression 71_307 S-Series General 3 08-14-2003 07:54 AM
