Old 01-02-2007, 08:37 PM   #1
minnidog
minnidog is on a distinguished road
minnidog's Avatar
Question Advantage Extended Warranty?
My dealer tried to sell me a 5yr/75K mile warranty to fix things not covered by GM's 5/100K for my new Aura. $1000 from Advantage.
Claims it's better than an extended warranty from GM.
What are some thought out there?
I had bought one before for a Pontiac minivan (wife's, NO man should drive a minivan, Ha Ha)and it saved me a couple of times.
Minnidog
Add to minnidog's Reputation
Rate the quality of this post and help minnidog reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
minnidog is offline   Reply With Quote
Old 01-02-2007, 11:06 PM   #2
ChuckTheGreat
ChuckTheGreat is on a distinguished road
ChuckTheGreat's Avatar
2008 Outlook XE
Default Re: Advantage Extended Warranty?
If the car is still under factory warranty, I always suggest you go with the Manufacturer's Extended Warranty. The aftermarkets are mostly ok but some dealers won't accept them if they have had difficulty getting paid.
Check out saturnextendedwarranty.com
Good Luck!
"If you are gonna lose, lose big, lose early and get the subs in."
www.buysubaruaccessories.com
www.buymazdaaccessories.com
Add to ChuckTheGreat's Reputation
Rate the quality of this post and help ChuckTheGreat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ChuckTheGreat is offline   Reply With Quote
Old 01-03-2007, 10:02 AM   #3
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
OK, so the warranty basically gives you 2 more years and 39K miles of coverage for non-powertrain items. For $1000? A rip off if you ask me. Sure, you MIGHT have more than $1000 in repairs during that two year window, but the chances are slim. Remember, the powertrain warranty covers a lot of stuff.
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline   Reply With Quote
Old 01-03-2007, 10:23 AM   #4
SKYGUY10066
SKYGUY10066 is on a distinguished road
2007 AURA XR
Look at miles people! The years are not the issue nowadays. Better to go with the longer mileage increment than longer in years unless you really don't get out much.
The powertrain warranty is great but really how many times does the engine/trans go out? Not often. As a sales person I ALWAYS buy the ext. warranty, Hey even at our Honda and Toyota store (Worlds Best Quality [yeah right]) They sell extended warranties 60% of the time.
I say it's worth it up to about 1500 for a longer mileage warranty. My insider tip? Deal on it ask for a discount maybe 200$ maybe 400$. Just get one, they cover rentals and all the non ware items.
Add to SKYGUY10066's Reputation
Rate the quality of this post and help SKYGUY10066 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SKYGUY10066 is offline   Reply With Quote
Old 01-03-2007, 01:14 PM   #5
spencerb
spencerb's Avatar
2008 Astra XR
How many people needed >$1,000 in repairs to non-powertrain items between 36K and 75K miles? Sure, it happens. But not very often.
The only out of warranty repairs I've needed on my VUE were my front wheel bearings, which are now covered under the GM 100K warranty. I just hit 60K.
Get the warranty if you want peace of mind. But remember that it's a gamble, and it's not in your favor.
Old 01-03-2007, 06:12 PM   #6
hugh
hugh will become famous soon enough
Front wheel bearings are part of the powertrain ???
Add to hugh's Reputation
Rate the quality of this post and help hugh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hugh is offline   Reply With Quote
Old 01-04-2007, 09:56 AM   #7
spencerb
spencerb's Avatar
2008 Astra XR
Here is what the 100K warranty covers:
Engine
Cylinder head, block, timing gears, timing chain, timing cover, oil pump/oil pump housing, OHC carriers, valve covers, oil pan, seals, gaskets, turbocharger, supercharger and all internal lubricated parts as well as manifolds, flywheel, water pump, harmonic balancer and engine mount. Timing belts are covered until the first scheduled maintenance interval.
Transmission/Transaxle/Transfer Case
Case, all internal lubricated parts, torque converter, transfer case, transmission/transaxle mounts, seals, and gaskets.
Drive Systems
Final drive housing, all internal lubricated parts, axle shafts and bearings, constant velocity joints, axle housing, propeller shafts, universal joints, wheel bearings, locking hubs, front differential actuator, supports, front and rear hub bearings, seals and gaskets.
Courtesy Transportation Program
During the warranty coverage period, alternate transportation and/or reimbursement of certain transportation expenses will be available under the Courtesy Transportation Program if your vehicle requires warranty repairs. Several transportation options are available. Refer to your Owners Manual for details, including reservation of rights, or consult your dealer/retailer.
Roadside Assistance Program
General Motors is proud to offer the response, security, and convenience of the 24-hour Roadside Assistance Program for a period of 5 years or 100,000 miles/160,000 kms., whichever comes first. Refer to your Owner Manual for details, or consult your dealer/retailer. The Roadside Assistance contact information is listed in the Customer Assistance Offices section of the Warranty and Owner Assistance Information booklet.
Old 01-04-2007, 10:39 AM   #8
SKYGUY10066
2007 AURA XR
It is something you can canel with a prorated refund down the road. I tell people to moniter any issues with the vehicle within the warranty and then based on that cancel if no problems exist. Just my 2cents
Extended warranty onefortheroad Aura General 2 12-17-2008 06:40 PM
GM Extended Warranty cooleydd Ion General 0 07-23-2008 03:41 PM
Extended Warranty / Warranty by net? saturnfreak01 General Saturn Discussion 9 10-27-2003 04:52 PM
Warranty America; Saturn Extended Warranty jb12 General Saturn Discussion 27 10-16-2002 01:26 PM
extended warranty billchez General Saturn Discussion 31 03-27-2002 03:06 PM
