Old 04-12-2013, 09:14 PM   #1
travlincub321
travlincub321 is on a distinguished road
travlincub321's Avatar
2002 VUE 3.0L
Default Corroded Pipe for Thermostat and Housing?
So heres the deal: My mechanic has my vue apart and is trying to replace the thermostat... However and I am not clear on what he's describing, there is a pipe coming from the block thats corroded and he cant get the thermostat out of there with out cutting it... Help?? Any ideas?? Thought? Diagrams..I am 2400 miles away and just had a bad car wreck today and my mercedes got totaled, so I am sorta stranded here right now until that gets solved, but now I reall need the VUE fixed and fixed right...
HELP
Add to travlincub321's Reputation
Rate the quality of this post and help travlincub321 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
travlincub321 is offline   Reply With Quote
Old 04-12-2013, 09:50 PM   #2
Default Re: Corroded Pipe for Thermostat and Housing?
If I'm not mistaken, L300 3.0L V6 engines are the same as Vue 3.0L V6 engines so the thermostat, housing, and extension outlet pipe running to the front of the engine should be in the same place. If my presumptions are correct then there's one bolt holding the extension pipe from engine vibration, the oil dipstick clamp? See if you can talk to your mechanic to free the extension pipe. The pipe simply slips over the t-stat housing outlet and seals with two simple O-rings. Once the oil dipstick clamp bolt is removed the extension pipe is free to remove. Corrosion won't weld the pipe to the t-stat housing if I'm not mistaken. Your mechanic may not see this clearly.
I replaced my t-stat several years ago.................
VCX NANO
Old 04-12-2013, 09:55 PM   #3
Chazberry
Chazberry's Avatar
1995 SW2
You might want to get another mechanic.
There's 1 bolt that holds the T'stat Housing Extension Pipe.
After removing the bolt, it unplugs from the T'stat Housing - with some wiggling.
(2 O-rings at the arrow)
You then have to remove the Intake Manifold to unbolt and remove the T'stat Housing.
http://www.saturnfans.com/forums/att...5&d=1283999373
Add to Chazberry's Reputation
Old 04-14-2013, 12:07 PM   #4
travlincub321
2002 VUE 3.0L
Marc seems to do good work and works on lots of wierd cars, I just hink its a lack of knowledge... This helps
Old 04-14-2013, 02:43 PM   #5
Chazberry
Chazberry's Avatar
1995 SW2
You might caution him about the tab on that Ext Pipe - seems it breaks off more often than not. Someone here suggested tightening that one bolt before torquing down the T'stat Housing.
http://www.saturnfans.com/forums/att...9&d=1331411332
Thermostat Extension pipe / coolant pipe yzracer14 Vue General 10 05-26-2014 11:03 PM
thermostat housing laser3kw S-Series General 1 05-17-2011 09:20 PM
Thermostat Housing ehunter S-Series Tech 105 04-14-2011 05:17 PM
Charged for thermostat housing?!! saturnmom77 S-Series General 10 03-10-2009 12:23 AM
L300 Thermostat housing dwmac L-Series Tech 3 02-19-2007 02:04 AM
