Old 01-27-2013, 06:10 AM   #1
derrickweber
derrickweber is on a distinguished road
Default oil in my coolant resivore
i have oil in my coolant resiore an im not sure what it is from. my car is running jus fine there is lil crack n my coolant resivore so i have to add coolant about once a week. but last time i checked it there was black stuff in it so i put my finger in it an it was oil an smelled liked gas. i jus checked my transmisslon fulid an it is a milkiey pink color but my oil is jus fine its not chocolatly like a blown head gasket would be so im stuck any help would b great thanks
Add to derrickweber's Reputation
Rate the quality of this post and help derrickweber reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
derrickweber is offline   Reply With Quote
Old 01-27-2013, 06:45 AM   #2
Squareback
Squareback is a jewel in the roughSquareback is a jewel in the roughSquareback is a jewel in the roughSquareback is a jewel in the rough
Squareback's Avatar
2005 ION-2 Sedan
Default Re: oil in my coolant resivore
Based on the assumption that you have a SOHC motor, and of course it's only an assumption because you didn't provide any information as to what you're working on, you have a cracked head. Very common with SOHC motors. You'll need to replace the head and thoroughly flush the cooling system with degreaser to get all of the oil out of it. When I worked for Saturn I always flushed the cooling system before removing the cracked head so the system was clean before reassembly with a new head. Also not a bad idea to replace all of the hoses and the thermostat while you have it apart.
One more thing... r-e-s-e-r-v-o-i-r.
Search the forum for cracked head, you'll have all of the information you need.
Certified Saturn Technician
Add to Squareback's Reputation
Rate the quality of this post and help Squareback reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Squareback is offline   Reply With Quote
Old 01-27-2013, 08:17 AM   #3
Tommie
Tommie is a jewel in the roughTommie is a jewel in the roughTommie is a jewel in the rough
1996 SL1
2002 SL1
If the transmission fluid is getting into the coolant, the transmission cooler may be leaking into the rad or vice versa.
Chocolate coolant reservoirs are usually a cracked head on SOHC and quite depressing.
Add to Tommie's Reputation
Rate the quality of this post and help Tommie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tommie is offline   Reply With Quote
Old 01-27-2013, 01:02 PM   #4
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
I had lots of problems with with '95 thru '97 DOHC engines. Porous heads (defective castings?) were the problem and the milkshake in the coolant bottle was the result. Like Squareback said, more information will yield better results.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 01-27-2013, 01:20 PM   #5
el diablo viejo
el diablo viejo will become famous soon enough
el diablo viejo's Avatar
1994 SW1
2000 SW2
[QUOTE=Tommie;1947679]If the transmission fluid is getting into the coolant, the transmission cooler may be leaking into the rad or vice versa.
Triple check your ATF and if it is milky pink through and through then you may luck out and only need a new radiator. Of course you will have to completely drain out the old ATF, which would require multiple drain/refills. You should not power flush the auto trans.
97 sl2 a/t 104 K
1989 GMC 3500 454 129 K, 1969 442 455 rat rod
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
el diablo viejo is offline   Reply With Quote
Old 01-28-2013, 01:18 AM   #6
CND_SC1
CND_SC1 is on a distinguished road
CND_SC1's Avatar
1994 SC1
Yes to the multiple drains & refills, but in this case OP should also drop the the tank to pour out & scrub any leftovers. No point doing all the work this car seems to require only to leave behind some coolant-contaminated ATF that could further shorten the Transmission's life.
My next thought would be that driving a few miles with a can of TransTune before the first drain might dilute the contaiminated fluid and lower the viscosity so more of it would run off surfaces and collect in the tank for draining. Is that a sound theory? Or is there any risk of harmful reaction from introducing TansTune to the ATF in the presence of coolant?
'94 navy blue SC1 from 04.2004 to 04.2011 which retired undefeated!
Add to CND_SC1's Reputation
Rate the quality of this post and help CND_SC1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CND_SC1 is offline   Reply With Quote
'98 SC2 - High Engine Coolant Temp and Low Coolant Level Warning Light mystic54 S-Series Tech 3 01-17-2013 09:29 PM
94 sc1 sohc oil in coolant bottle, no coolant in crankcase? cracked head? gman41 S-Series Tech 40 10-16-2011 11:04 PM
Low coolant level and High coolant/transaxle fluid temperature nls S-Series Tech 2 08-30-2009 09:46 AM
low coolant level light on but plenty of coolant in reservoir smote S-Series Tech 2 11-11-2008 01:04 PM
Coolant light coming on but coolant level is fine. Help? Writerbecky12 Ion Tech 9 06-21-2008 03:11 PM
