Old 06-23-2012, 11:32 PM   #1
Biral
Biral is on a distinguished road
Default Quick Question
How do you replace the 12v dc housing. I've pulled the old one out, and i bought a universal one. No matter what i do it will not work. I've tryed crimped spade connector, but nothing seems to work. I need help
Add to Biral's Reputation
Rate the quality of this post and help Biral reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Biral is offline   Reply With Quote
Old 06-23-2012, 11:46 PM   #2
hoseppi
hoseppi will become famous soon enough
hoseppi's Avatar
2002 SL1
2008 Astra XE
Default Re: Quick Question
You may want to clarify your question.
Add to hoseppi's Reputation
Rate the quality of this post and help hoseppi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hoseppi is offline   Reply With Quote
Old 06-23-2012, 11:51 PM   #3
Biral
Basically I have a 97 SL2, and I'm trying to replace a simple cigarette adapter. I pulled the old one out and cut the housing off. None of the universal ones will work so it might be wiring. I'm just curious to see if anyone may have an idea as to what I can try to get it to work.
Old 06-24-2012, 12:11 AM   #4
off-track
off-track's Avatar
?!? Are you talking about the orange ring? This is the lighter socket removal how-to:
http://www.youtube.com/watch?v=khTqYKWeLVY
No "cutting" involved.
Have you checked the fuse and/or verified the socket is indeed the problem?
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Rate the quality of this post and help off-track reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-24-2012, 12:27 AM   #5
Biral
I bought my car used, and the previous owner didn't take care of it. So i'm going through hoops to fix this car. I know where the fuses are, but i couldn't locate the fuse for the cigarette adapter. The fuse diagram in the care isn't that helpful if you don't know what the abbreviation stand for. Getting back on to subject I did cut it, but I kept all the parts. I can fix my mistake if i need to. Thanks for the video though.
Old 06-24-2012, 12:32 AM   #6
Pull all the fuse's and check for blown ones. If your not sure about one then test it's connectivity with a DMM, or just replace it. The relay's generally don't fail without accompanying visual aid's (melted plastic) so you shouldn't have to worry about those.
Old 06-24-2012, 01:11 AM   #7
off-track
off-track's Avatar
If you pull the panel cover on the passenger side of the console there is a diagram on the back side. You would be looking for fuse #13 that's labelled as "lighter". A yellow 20A mini-fuse in the lower right corner right above the fuel pump relay.
Added OEM CC
Old 06-25-2012, 10:10 PM   #8
adventureoflink
adventureoflink's Avatar
if I were you, I'd just go ahead and run a new constant hot power wire going to the power adaptor. Do it, since re-using the current wiring can lead to burning of the F-5.
You should be able to use the existing ground wire, though.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Quick RKE Question As Well! holydiver S-Series Tech 9 07-13-2011 08:54 PM
quick question activeEXvue Vue General 2 06-14-2007 01:49 PM
quick quick quick question about flywheel. Jinjo S-Series General 3 09-07-2006 10:31 AM
quick question 96SaturnSc1cp S-Series Tech 9 08-30-2006 10:29 PM
Quick Question and not so quick one... John Marshall Miscellaneous Tech 5 02-19-2004 11:22 AM
