Old 04-15-2011, 09:22 PM   #1
fyregrl7
fyregrl7 is on a distinguished road
Default coolant temp sensor
hello! first i want to say this is my first post and thank you for all the wonderful info.....you guys have really saved my car and sanity!!
i have a 98 saturn sl2 which i have been driving and recently replaced the cts. however the wire harness is no longer working even though it looks fine. i read somewhere on there these are the same plug/harness as something else on the car....o2 sensor???.i can not find the info again. the reason im asking is i have a 99 sl2 with front end and sub frame damage that i bought as a parts car and since its beyound repair i would love to salvage as much as possible and keep my 98 on the road. since iv found out the issues my car has is not all that terrible, im actually starting to love this car and fixing it!
thanks for any help
Add to fyregrl7's Reputation
Rate the quality of this post and help fyregrl7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fyregrl7 is offline   Reply With Quote
Old 04-15-2011, 09:28 PM   #2
ehunter
ehunter has a spectacular aura aboutehunter has a spectacular aura about
Location: Pacifica by San Francisco 5sp Engine rebuild with the help of people here at 177K due to 500mi/qt oil consumption. After 2yrs I am back to 40mpg+ after discovering the refirb head I used was bad. Car runs better than a top. Now at 214k.
1996 SL2
Default Re: coolant temp sensor
Rockauto.com has the sensors' replacement connectors you can solder(recommended way) into your replacement wiring. My stuff arrives in 2 days.
I dont recommend the computer connector type referenced in other posts. Though they fit well there is too much involved in sealing the connector from the elements.
look under "electrical-connector" for your make and model.
Add to ehunter's Reputation
Rate the quality of this post and help ehunter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ehunter is offline   Reply With Quote
Old 04-15-2011, 10:02 PM   #3
fyregrl7
perfect thanks....actually i just realized the wire has been replaced before but the wires were not soldered they have a connector...ill try cutting back and soldering first if thats a no go then im going straight to the site and ordering
Old 04-16-2011, 01:38 AM   #4
Signmaster
The connector is also the same as the IAT (Intake Air Sensor) that is located in the intake snorkel in front of the airbox. You could steal that off of your parts car or any unsuspecting junk yard cars.
LowSaturn has a bunch of them if you need one.
ehunter,
Are the Rockauto connectors just like OEM with the squeeze tabs to remove them?
Old 04-16-2011, 06:52 AM   #5
ECTS (2wire), IAT, and the autotragic Trans fluid temp sensor all use the same connector. Same sensor too, but the ECTS gets all the love while the others get abandoned. The others generally don't fail so it's not really a problem.
Old 04-16-2011, 07:25 PM   #6
fyregrl7
perfect thanks!!
Coolant Temp Sensor? gr8gonzo0 S-Series Tech 2 05-12-2009 09:21 AM
coolant temp sensor or what??? RMracing125 S-Series Tech 2 02-19-2007 07:31 AM
coolant temp sensor danbandMN S-Series Tech 1 11-24-2005 12:29 AM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
Coolant Temp Sensor MDSaturnSL2 S-Series General 19 12-23-2003 08:23 PM
