Old 03-03-2019, 01:22 PM   #1
Dach
Dach is a jewel in the roughDach is a jewel in the roughDach is a jewel in the rough
Default Low washer fluid and it's not the sensor...
So my wife's '01 l200 is going away soon and I have the washer fluid warning to deal with first. I should have just checked the plug with a jumper, but I bought a new sensor and it didn't work. I ohmed it out and it and the original are good. I jumpered the plug and still have the warning. I know it goes through the BCM but that seems to be a stretch to think that's the problem since that is the only issue I'm having. I was wondering if anyone else has had this or if someone could show me wiring diagram so I can check for continuity at various points. I could just tear off the conduit and tape, but that may be my only/last resort. TIA.
Add to Dach's Reputation
Rate the quality of this post and help Dach reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dach is offline   Reply With Quote
Old 03-03-2019, 02:48 PM   #2
Russet
2002 L-Series 3.0L Sedan
Default Re: Low washer fluid and it's not the sensor...
Did you get something like a Haynes and check the wiring diagrams to trace it?
Add to Russet's Reputation
Old 03-03-2019, 07:58 PM   #3
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Post Re: Low washer fluid and it's not the sensor...
This may help!!
1995 SL1 236,300 2005>2018
1997 SL1 71,400 21 yrs. and Legal!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
SRGW is online now   Reply With Quote
Old 03-04-2019, 03:09 PM   #4
Dach
Thanks, that will help.
Old 03-04-2019, 10:25 PM   #5
Wayne G.
Wayne G. is a name known to allWayne G. is a name known to allWayne G. is a name known to allWayne G. is a name known to allWayne G. is a name known to allWayne G. is a name known to all
2001 L-Series 3.0L Sedan
I have the identical issue with my L300 - light stayed on after filling, replaced sensor , light still on, jumper - ed the plug to sensor light still on. Closed circuit should turn off alert lamp, open circuit - lamp on. No obvious breaks in wire. let us know how you fix it. Any suggestions?
Add to Wayne G.'s Reputation
Rate the quality of this post and help Wayne G. reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Wayne G. is offline   Reply With Quote
Old 03-05-2019, 04:59 PM   #6
Dach
I jumpered a wire from ground to both sensor wires. The schematic helped me a lot with this. Touching the black white made the dash light go off so I knew I was missing the ground. I checked where the black was connected to the ground connections just under my battery tray. I had a battery leak about 15 yrs. ago and it must have finally eaten away the ONE wire that went to the sensor. I just ran a new ground to the remaining black wire and that did it. Thanks again to SRGW for the schematic.
Saturn 2000 L200/Washer Fluid Sensor Wreckapotamus L-Series Tech 3 04-28-2018 08:43 PM
Washer Fluid eb121209 S-Series General 17 06-17-2014 01:52 PM
washer fluid doubleb99 Astra General 1 06-14-2010 10:28 PM
Odd-looking washer fluid karinhesed86 S-Series General 28 01-19-2006 12:14 AM
low washer fluid sensor PaulN64 L-Series Tech 14 10-27-2004 11:01 PM
