Old 04-04-2011, 05:53 PM   #1
camzshaft
camzshaft has a spectacular aura aboutcamzshaft has a spectacular aura about
Default 2002 Sc2, what is the name of the reverse light housing located on the bumper?
I need to get a new set and I can't find them anywhere! I also don't know what they're actually called so any search I do only ever shows me results for tail lights.
Add to camzshaft's Reputation
Rate the quality of this post and help camzshaft reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
camzshaft is offline   Reply With Quote
Old 04-05-2011, 02:57 PM   #2
camzshaft
Default Re: 2002 Sc2, what is the name of the reverse light housing located on the bumper?
Nobody? Not even a gentle prod in the right direction so I can find out myself?
Old 04-05-2011, 03:09 PM   #3
BV22
2002 SC1
Try "back up lamp housing".
Add to BV22's Reputation
Old 04-05-2011, 03:23 PM   #4
http://www.trademotion.com/partlocat...layCatalogid=0
if that astronomically long link doesn't work:
GetSaturnParts.com ->Input car info->Rear lamp->Backup Lamp->Backuplamp Assembly. $25.13 per side, right & left different.
Old 04-05-2011, 03:41 PM   #5
camzshaft
Thank you
Old 07-08-2016, 05:24 PM   #6
KSabo
KSabo is on a distinguished road
KSabo's Avatar
Also, thank you - I was just looking for the correct GM # for these. Much appreciated.
Black 2002 SC2 manual 1.9L DOHC - 210,000 miles (July 2017)
Add to KSabo's Reputation
Rate the quality of this post and help KSabo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KSabo is offline   Reply With Quote
Reverse light fuse located where? destro5 S-Series General 3 05-25-2008 12:48 AM
Tail Light Housing Melted edisonline L-Series General 10 05-13-2008 03:37 PM
Removing Sunroof/Map Light housing zeemo13 S-Series Tech 0 05-05-2007 10:59 AM
rear reflector/ reverse light housing $? fetchitfido S-Series General 0 06-24-2006 08:56 AM
Moisture in rear singnal/reverse light housing Son93SL2 S-Series Tech 2 05-27-2000 08:28 PM
