Old 02-28-2011, 01:28 AM   #1
adventureoflink
adventureoflink's Avatar
Dizzy 2000 LS2 speaker/radio installation
Okay, this is for a friend of mine.. she's asked me to replace the speakers and radio deck in her LS2. problem is, best I've been able to come up with here are the specs for the speakers:
* 6.5" up front
* 5.25" in the rear
* 3/4"-1" spacer to go in between the door panel and speaker for the front speakers (from my understanding it's mostly for the window glass IIRC)
...correct? ALSO: there's only two fronts and two rears, right?
Now, the questions I have are these:
1. how does one R&R the front inside door panel or the speaker grille if it's that simple (and if there's pictures and/or a video it'll help greatly )?
2. how does one gain access to the rear speakers; is it like the S-series where it's in a package tray? if so, how does one R&R that?
3. what be the wiring codes for the speakers? is it the same as the S-series, or is there something complicated?
and 4. ultimately, how does one gain access to the radio deck? is it like gen-2 S-series where I have to pop off the center console and I'm in, or do I have to dig through the dash/steering column like in gen-3 S-series, or...?
Any and all help is appreciated. Thanks in advance.
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-28-2011, 01:50 AM   #2
adventureoflink
Default Re: 2000 LS2 speaker/radio installation
OK, Google actually just turned this up for the front door panel:
http://www.ehow.com/how_6572901_apar...oor-panel.html
However, the source is from a HAYNES manual, which in my experiences from the S-series section, unless it's an actual FSM, it's not worth the paper it's printed on. In any case, is this accurate?
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 02-28-2011, 10:33 PM   #3
born again
2000 L-Series 2.2L Wagon
Those instructions aren't even close. I wrote this up a while ago for the rear panel-
http://www.saturnfans.com/forums/sho...+panel+removal
The front is similar, but you also have the mirror control switch to remove and there are a few screws securing the bottom edge to the door.
Old 02-28-2011, 10:37 PM   #4
adventureoflink
that's what I thought. ( haynes manuals...) thanks for the write-up, I'll be sure to go over that and compare it to what I found on alldata this afternoon (I'm going to college right now for auto and diesel mechanics). I also found there how to R&R the control console where the radio is.. I must say it's actually easier to do than any S-series on the road
however, the alldata didn't mention anything about speaker spacers though... judging by your write-up, all I have to do is remove the tweeter cover (which is IIRC the front door speakers) in addition to everything else in your write-up to get to the speaker, right? Or does the door panel still have to come all off?
I also found on alldata that there's also a subwoofer underneath the rear package tray (depending on options).. is the rear package tray R&R the same way as it is on the S-series?
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 03-02-2011, 04:05 PM   #5
adventureoflink
**BUMP**
anyone?
also I found stuff about tweeter speakers, woofer speakers, and the subwoofer.. what does all this mean actually?
(keep in mind I'm used to swapping out four speakers (two in front two in back) so I have no idea what they're talking about...)
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Speaker installation darkwing S-Series General 3 01-10-2009 10:04 PM
Speaker installation...need help. xround3x S-Series Tech 0 03-19-2007 04:48 PM
Speaker installation gaurdien Vue General 0 09-28-2005 06:58 PM
Speaker Installation for 1st Gen SL2 JOKERSL2 S-Series General 1 02-15-2005 08:33 PM
NEED HELP: Speaker Installation! jbakert` Mods and Performance 1 01-11-2005 02:02 PM
