Old 07-13-2019, 08:37 PM   #21
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
1997 SC2
Default Re: light that indicates low coolant is coming on lately
Originally Posted by changeling616 View Post
Actually, I was looking from above, on the driver's side. Top of photo is closer to the windshield, and bottom is towards headlights.
Is there any other solution than replacing the radiator?
Not really - no one on this forum will recommend those "stop leak" solutions. They eventually cause more problems (ruining your stuff) and you're not actually fixing the problem.
The radiator is not a hard job, but there's a fair amount of things to take out. If you're handy with tools, it will only take an afternoon. The radiator itself is like $60.
Here's a richpin video on its removal. Take a look and see what you think.
https://www.youtube.com/watch?v=4nUyGjeLpVs
If you do go with a replacement, check your hoses, thermostat and water pump. If you're thinking long term - it might be worth doing them all at the same time since you're doing a coolant flush.
Add to blueknigh7's Reputation
Rate the quality of this post and help blueknigh7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blueknigh7 is offline   Reply With Quote
Old 07-14-2019, 02:31 AM   #22
changeling616
changeling616 is on a distinguished road
Originally Posted by trottida View Post
This is likely your issue. It took me a while to figure your photo was looking up from the bottom.
I replied to you post earlier, saying my photo is from above. However, I am not sure what you were trying to say...?
Add to changeling616's Reputation
Rate the quality of this post and help changeling616 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
changeling616 is offline   Reply With Quote
Old 07-14-2019, 02:34 AM   #23
changeling616
Thanks for the advice. Where do you suggest getting a radiator?
I'm getting better at servicing my car. Changed the oil and filter a few days ago, and changed the wheels around (what they usually call "rotating the tires" - phrase that does not make much sense to me, even though I know what people mean by that).
Old 07-14-2019, 02:52 AM   #24
changeling616
I asked where to get a radiator. Is it worth going to a parts yard? If you get one from another Saturn, I would think there is no way to know for sure it would last - it could go bad in a few days, after you put money and work into it.
Old 07-14-2019, 08:30 AM   #25
I'd go to Rock Auto.
https://www.rockauto.com/en/catalog/...,radiator,2172
Add to Waiex191's Reputation
Old 07-15-2019, 01:31 AM   #26
changeling616
Originally Posted by Waiex191 View Post
I was not sure if you had it on the right page - does SC1 have a different radiator that SC2? Mine is a 2001 SC2.
I am attaching an image that shows that RockAuto does not seem to have different info/products for SC1 and SC2 coupes. Does that mean that the products that have are for both SC1 and SC2? And if so, should I trust that they are doing it right?
Old 07-15-2019, 06:54 AM   #27
That is the right page. SC coupe > 1.9L L4 DOHC is an SC2. The radiators in all S Series Saturns are the same, which is awesome.
If you look under > 1.9L L4 SOHC you will find the same parts. Or SL, or SW.
Old 07-15-2019, 08:05 AM   #28
VUEmaniac
1997 SC2
Definitely don't bother with a used one. They are cheap and plentiful either online or at your local auto parts store. I'd probably get this one at Rockauto:
SPECTRA PREMIUM CU2191
Best,
Don't blame a clown for acting like a clown. Ask yourself why YOU keep going to the circus.
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-15-2019, 08:25 AM   #29
trottida
trottida's Avatar
I was referencing the included quote and its photo showing the area that typically cracks on the S Series radiator. It's a photo looking square on rather than from the top down like yours.
I thought your photo was from the bottom looking up as I don't recall the trans cooler line being so high up on the radiator. My radiator photo is from a manual transmission however.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 07-15-2019, 02:44 PM   #30
blueknigh7
1997 SC2
So the radiator is probably the next step higher in terms of difficulty. If you have a friend who's handy on cars, it may be worth "pizza and beer" just to have them look over your shoulder. Again, not hard, but just make sure you have tools and equipment handy (appropriate sockets, drain pans for coolant, etc). Nothing's worse than getting halfway through a job and then getting stuck because you don't have the right tool.
I'd echo the rockauto part recommendation above. Shipping costs can be a pain, but I remember the days before "free shipping", and then compare against the "total cost" of buying from my local auto parts store. If you can wait, then rockauto is usually the cheapest option. Radiators are $120 to $160 at my local stores.
Old 07-15-2019, 08:32 PM   #31
changeling616
Thanks.
Old 07-15-2019, 08:33 PM   #32
changeling616
I watched the YouTube video that someone linked. I think I can do this.
I don't have any friend who is a mechanic to offer pizza and beer to, however....
Old 07-16-2019, 09:21 AM   #33
Post your location. Might be someone here who is willing to watch you work while eating your pizza and drinking your beer
(make sure they pack tools in their trunk in case you are missing something but from what I remember, it only required a few basic tools)
Old 07-16-2019, 11:08 AM   #34
changeling616
Grand Rapids area (city of Wyoming), Michigan, USA
Old 10-05-2019, 09:43 AM   #35
changeling616
I ordered and got the radiator some time ago. I plant to install it today. On the box, it says to replace that thermostat at the same time. Is that all that important?
Old 10-05-2019, 09:50 AM   #36
changeling616
I checked AutoZone and O'Reilly Auto Parts online. AutoZone gives one model available at their store - Duralast Thermostat and Housing Assembly 15178. O'Reilly gives 2 - Murray Plus Thermostat Housing Assembly Part # 3179 Line: MCS and ACDelco Thermostat Part # 12T49D Line: ACD . Is there a better or best in this list?
Old 10-05-2019, 10:04 AM   #37
changeling616
OK, I did a quick search on Duralast and Murray. A lot of people say that AutoZone - in this case Duralast - are not good.
NAPA has 3
Thermostat and Water Outlet Assembly
Part # :
NBH 33528
Product Line :
NAPA Belts & Hoses
Thermostat and Water Outlet Assembly - OE Temp
Part # :
THM 268
Product Line :
NAPA Thermostats
Part # :
BK 6051898
Product Line :
Balkamp
Old 10-05-2019, 10:37 AM   #38
changeling616
I called a local NAPA store and found that only the second one I lists,
Part # :
THM 268
Product Line :
NAPA Thermostats
Is still available. She said the other two were old part numbers.
I plan to buy this one.
Old 10-05-2019, 10:51 AM   #39
If your thermostat is good, it is not critical. But, since you have to drain the coolant and will have more space with the radiator out, it is convenient.
Old 10-05-2019, 11:38 AM   #40
changeling616
Thanks.
Coolant coming out of resivour Cap Wyattgc S-Series Tech 25 05-06-2018 07:03 PM
Coolant light coming on, radio & clock blank out on occasion Miesha Ion Tech 5 09-19-2011 12:51 PM
Coolant light coming on but coolant level is fine. Help? Writerbecky12 Ion Tech 9 06-21-2008 03:11 PM
Saturn SL-1 2002 - Coolant Light/Coolant Leak - Muffler noise - Check Engine Light unabelladonna S-Series Tech 1 02-26-2007 12:56 PM
Coolant light and coolant level light flash after gunning it? FightingChance S-Series Tech 7 10-07-2006 11:03 PM
