Old 07-01-2004, 04:26 PM   #1
1993
1993 is on a distinguished road
Default EGR or solenoid for sure?
93 sl-1, single cam motor, getting a code 32 wich is for the EGR, i unplugged the vaccuum line from the EGR, pushed up the plunger in the valve and put my finger over the nipple on the EGR housing and the plunger stays up as long as i hold my finger over the hose nipple, so i am assuming the EGR valve itself is good and the solenoid is what is bad???? Just want to be sure because the dang solenoid is 34.04 from the dealer!! Or is the autozone solenoid good enough or is it one of those things where the dealer item is better to use?
thanks
Add to 1993's Reputation
Rate the quality of this post and help 1993 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
1993 is offline
Old 07-01-2004, 07:48 PM   #2
amazinghl
Default
Did you try to clean the EGR valve?
EGR solenoid's code is 26...
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 07-01-2004, 08:43 PM   #3
1993
Default
but the EGR valve works..? The plunger moves up and down and if i push it up and then plug the vacuum hole in it, it will hold itself up until i let my finger off of the vacuum tube, doesnt that mean its good? i remember that was the old way of testing them, the one on my truck is bad, it wont stay up wheni plug the vacuum tube..?
1993 is offline
Old 07-01-2004, 09:19 PM   #4
gdelgrego
gdelgrego is on a distinguished road
2007 AURA XE
1992 SL2
Default
There are more tests than the one you tried. It could still be plugged if you're trying this on a not running engine. Read this thread for more tests. ..
http://www.saturnfans.com/forums/sho...threadid=24751
07 Aura XE
92 SL2
Add to gdelgrego's Reputation
Rate the quality of this post and help gdelgrego reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gdelgrego is offline
Old 07-03-2004, 07:42 PM   #5
1993
Default
ok, when exactly is the EGR supposed to operate, when revving or decelerating or what? I want to know so i can check it with the motor running..?
1993 is offline
Old 07-03-2004, 08:17 PM   #6
Default
If you do the tests in the link that gdelgrego provided you will be able to eliminate the EGr valve. Are you getting any other codes besides 32?
Add to ssicarman's Reputation
ssicarman is offline
Old 07-03-2004, 08:31 PM   #7
gdelgrego
2007 AURA XE
1992 SL2
Default
The tests in the link are the proper way to verify valve operation, but since you asked (and it may help someone else), the vacuum EGR operates when (from a '93 FSM):
Coolant temp > 122 F for SOHC or DOHC with manual tranny. For DOHC with manual tranny, temp > 104F.
AND
Idle speed > 4% TPS
These two conditions trigger EGR ON and activate the EGR solenoid. The actual amount of EGR flow is controlled by the ratio of engine vacuum to exhaust backpressure, that is why any pluggage in the EGR system will affect operation even if the valve is opening/closing when commanded.
07 Aura XE
92 SL2
Old 07-03-2004, 09:50 PM   #8
wolfman
wolfman's Avatar
Default
Good description^ Code 32 generally indicates a LACK of EGR function. (Bad solenoid or valve) Code 26 AND 32 generally indicates a solenoid shorting to GROUND causing no EGR function. A solenoid NOT shorting to ground, but inoperative, will generally result in a code 32 ONLY.
Add to wolfman's Reputation
wolfman is offline
Old 07-04-2004, 07:05 AM   #9
1993
Default
i tried this also, i disconnected the vacuum hose from the EGR and revved the motor up, there was vacuum at the hose when i revved it..
1993 is offline
The EGR solenoid. jjsk8r85 S-Series Tech 5 06-30-2008 01:01 PM
93 SL-2 EGR solenoid. Alwaysdutch S-Series Tech 4 06-03-2007 03:29 PM
EGR Solenoid andyr13 S-Series Tech 4 07-15-2005 10:55 AM
EGR Solenoid iced_theater S-Series Tech 10 03-17-2004 11:16 PM
EGR Solenoid muzikmann Miscellaneous Tech 2 05-23-2003 04:45 AM
