Old 06-28-2008, 12:18 PM   #1
jjsk8r85
jjsk8r85 is on a distinguished road
jjsk8r85's Avatar
1992 SC
Default The EGR solenoid.
So I've had this problem for.....well, since i've owned my 92 SC, and it's been bugging me.
Whenever I connect the egr system as it's supposed to be, the car hesitates horribly during acceleration, up to about 3500 rpm. Disconnected, the car runs great. I've replaced the EGR valve, solenoid, and it's related vacuum lines. Yesterday, I went out with an analog multimeter and did some testing on the plug. For some reason, anytime the throttle is open any more than about 3%, the ECM is commanding the egr valve open (0 ohms to ground). At Idle, I'm not quite getting an open circuit to ground, as I should be. It sits right around ~10k ohms. Is this normal? As I understand, the egr valve solenoid is controlled by engine temp and speed. What else could be causing this?
I do get EGR and Quad driver codes when the system is disconnected, but no codes if it's connected properly.
92 SC 5-speed 239k miles
Add to jjsk8r85's Reputation
Rate the quality of this post and help jjsk8r85 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jjsk8r85 is offline   Reply With Quote
Old 06-28-2008, 01:10 PM   #2
Default Re: The EGR solenoid.
During idle when the engine is at its lowest rpm you have to ask yourself, does the engine need exhaust gas recirculation feeding exhaust into the fresh air intake system? The answer is no and the EGR valve is not used during idle speed. Wouldn't this dilute the air/fuel mixture enough to cause a leaner condition that can result in lowering the rpm, misfiring, stalling? Yes. With a vacuum EGR valve on a cold engine running, put your fingers under the round vacuum diaphragm cover to reach under it and pull the diaphragm; the engine will immediately stall as you are lifting the pintle valve from its seat allowing exhaust gas into the fresh air intake manifold. The EGR valve is always closed at idle and opens during acceleration and cruise. Closed during idle and closed during wide open throttle.
Old 06-28-2008, 05:02 PM   #3
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
Once more ;
The EGR solenoid only energizes at cold operating temps.
This function only blocks off the flow through the valve .
once operating temp. is reached (threshold) ,the valve has no current to it , allowing full flow to occurr ,from ported vacuum .
At idle there is NO ported vacuum ,to control .
Above idle ,there is varible amounts of vacuum ,depending on throttle position
The older cars used this to apply advance to the distributor spark timing advance. (ported vacuum )
Have A Great Day , it is YOUR choice !
Add to Dr B's Reputation
Rate the quality of this post and help Dr B reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dr B is offline   Reply With Quote
Old 06-29-2008, 02:46 PM   #4
jjsk8r85
jjsk8r85's Avatar
1992 SC
So then, what I've gathered is that the EGR system is functioning properly, and something else is causing the problem, and it only happens to occur when the EGR system is connected properly. I get misfires up to about 3000rpm when the system is connected properly.
Old 06-30-2008, 11:32 AM   #5
Dr B
Dr B's Avatar
1992 SL2
1993 SL2
My guess (idea) theory ect;
The fuel maps (ratios) the P C M has developed ,was without the E G R .
So now that it is working ,the maps are all wrong ,and need to be re-learned.
Old 06-30-2008, 01:01 PM   #6
jjsk8r85
jjsk8r85's Avatar
1992 SC
I've tried resetting the ECM also, sorry should have mentioned that before. I reset it when I put the new solenoid in.
93 SL-2 EGR solenoid. Alwaysdutch S-Series Tech 4 06-03-2007 03:29 PM
EGR Solenoid andyr13 S-Series Tech 4 07-15-2005 10:55 AM
EGR or solenoid for sure? 1993 Miscellaneous Tech 8 07-04-2004 07:05 AM
EGR Solenoid iced_theater S-Series Tech 10 03-17-2004 11:16 PM
EGR Solenoid muzikmann Miscellaneous Tech 2 05-23-2003 04:45 AM
