Old 01-17-2010, 09:57 PM   #1
lt1george
lt1george is on a distinguished road
Default BCM code U0073 What's does it mean ?
Anybody else have this code and what did the dealer to to correct it ? Thanks for your time and answers.
lt1george is offline   Reply With Quote
Old 01-17-2010, 10:25 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: BCM code U0073 What's does it mean ?
A U0073 isn't just a BCM code. Almost any of the vehicles systems can cause it.
The manual says the following modules can set a U0073:
BCM, DRR, EBCM, ECM, HVAC IPC, PSCM, Radio, RCDLR, RSA, SDM, TCM, TDM, and VCIM.
Could be somethig as simple as a loose electrical connector, low voltage situation, blown fuse or complete failure of one of the modules.
Gonna need a GM TEC2 to figure this one out.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 01-18-2010, 02:05 AM   #3
lt1george
Hi Mike, Thanks for the fast reply. Will bring it to Chevrolet Dealer tomorrow to have it checked out. Will let you know. Thanks again.>George
Old 01-18-2010, 11:16 PM   #4
lt1george
Mike , Dealer said there was a whole lot of codes in computer. They wanted to let a tech drive it home with a scanner hooked up. We said go ahead. Not very happy about this problem. Chevrolet Dealer was very nice, we know it's not his fault. Will let you know more as we find out.
ps I see Threxx has the same problem as we have, at least that's the exact same thing that happened to us with the security light coming on for no reason.
Old 01-19-2010, 09:55 PM   #5
lt1george
Picked up car and codes all cleared. Nothing showed overnight when tech took it home.
check engine code 11, coolant hot light flashes code 23, 95 SL2 2003MercMaraude S-Series Tech 2 10-23-2009 06:17 PM
Code Scanners vs. Code Readers, What to get? jeffghs S-Series Tech 2 10-12-2005 12:40 PM
Trans code 25, engine code 32, 1993 sl-1 1993 S-Series Tech 3 06-27-2004 11:13 PM
vin egine code to original code how to check? silver97sl General Saturn Discussion 1 01-12-2004 05:17 PM
code 26 - quad code - How to test dancingator Miscellaneous Tech 4 10-07-2003 08:58 AM
