Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 05-02-2004, 10:26 PM   #1
tenn734
tenn734 is on a distinguished road
tenn734's Avatar
Default motor mounts...again
are there any other performance motor mounts other than sps and sms... ?
for those with the sps ones, which are not exactly "solid mounts" ... is there a noticable improvement to warrant the money spent?
tenn734 is offline
Old 05-02-2004, 10:41 PM   #2
JDub99SL2
JDub99SL2 is on a distinguished road
Default
Prothane inserts. I've got them in my car. The only thing I really noticed is a little more sensitive gas pedal. It's worth it, if you don't mind the slight increase in vibration at idle. (800-900RPM, it gets kinda rattly), but my top mount isn't in the best of shape, (and is about to be replaced) so I couldn't tell you if the prothane inserts caused the problem or not. I only paid $30 for mine..
JDub99SL2 is offline
Old 05-02-2004, 11:33 PM   #3
TheSaturnKid
TheSaturnKid is on a distinguished road
TheSaturnKid's Avatar
Default
Yeah get the inserts rather than getting the SPS installed mounts. Much cheaper to put them in yourself. If you have a bench vise and a screwdriver, you can do it.
TheSaturnKid is offline
Old 05-03-2004, 12:12 AM   #4
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
Anyone know where to get the inserts without the dogbone housing?
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Applefool is offline
Old 05-03-2004, 12:58 AM   #5
Bigbadbert
Bigbadbert is on a distinguished road
Bigbadbert's Avatar
Default
I thought SPS sold them?
'01 SC2 - sold
Bigbadbert is offline
Old 05-03-2004, 08:49 AM   #6
JDub99SL2
Default
Yep, all you need is a vice and a screwdriver. Silicon spray lubricant helps out a big, deal, too. The trick to getting them in is to take out the metal cylinders in the middle (where the bolts go through).
I believe mine are from prothane.com
Old 05-03-2004, 09:49 AM   #7
Tycho
Tycho is on a distinguished road
Tycho's Avatar
Default
The CCG mounts are very nice also.
Forced induction is rape.
Tycho is offline
Old 05-03-2004, 12:09 PM   #8
tenn734
tenn734's Avatar
Default
everywhere i look they seem to car specific and i dont see any for saturns, just the usual honda, mitsu, acuras
tenn734 is offline
Old 05-03-2004, 03:02 PM   #9
Twin_Cam
Twin_Cam is on a distinguished road
Twin_Cam's Avatar
2000 SL2
Default
Summit sells the inserts, too.
'00 SL2m- DD, 186K miles
'05 Honda CR-V- wife's DD and my upright bass hauler
'84 Honda CB650SC Nighthawk- toy
Twin_Cam is offline
Old 05-04-2004, 03:08 AM   #10
Red97sc2
Red97sc2 is on a distinguished road
Red97sc2's Avatar
2001 SL2
2005 ION-2 Sedan
Default
Motor Mounts
Prothane inserts. They're only $25.99 from Summit. And that will do both dogbones. Part # PTP-7-510. Caution: Engine Vibration may significantly increase over stock.
2008 Dodge Grand Caravan.
2008 Nissan Altima
1970 Mercury Cougar: 351C, 4spd. Classic for shows.
2005 Subaru Impreza
2003 Grand Marquis
Red97sc2 is offline
Old 05-04-2004, 06:44 PM   #11
chrispel
chrispel is on a distinguished road
chrispel's Avatar
2001 SL2
Default
If you are going to use them inserts you will need after market motor mounts like the ones from autozone they are black. The stock ones I have tried to use were to small for them to fit in.
This is what it looks like after you install them.
92 SC2 V1 A Trim 5-10 PSI
98 SC2 DP Nitrous
chrispel is offline
Old 05-05-2004, 12:51 PM   #12
gm7
gm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the rough
gm7's Avatar
2009 VUE Red Line
Default
Chrispel...do you report the same vibration increase with Prothane that red97SL2 mentioned just above?
Thanks,
George...really like the Windo-weld mounts...very little vibration increase and much firmer
gm7 is offline
Old 05-23-2004, 03:06 PM   #13
tenn734
tenn734's Avatar
Default
sorry for resuscitating an old and tired subject but my questions are ...is there a noticable "performance" gain if you have an automatic? 'cos ive heard stiff mounts benefit manuals more... and not so much with autos.
also conversly wouldnt there be more NVH with an auto at idle??
thanks
tenn734 is offline
Old 05-24-2004, 11:57 AM   #14
gm7
gm7's Avatar
2009 VUE Red Line
Default
personally unless your have a high horsepower automatic car, I would leave the mounts stock in an automatic Saturn having driven a number of them...the torque converter is much more forgiving on driveline lash than a clutch is.
George
Windo-Welded stock mounts that I believe is a big improvement over stock with little NVH downside
gm7 is offline
Old 05-24-2004, 02:05 PM   #15
TheSaturnKid
Default
Yep, unless you are pushing 150HP+ in an auto, you dont need em.
Whats disturbing is, I WILL NEED THEM!!!
Hehehe...
Old 05-24-2004, 02:56 PM   #16
Twin_Cam
Twin_Cam's Avatar
2000 SL2
Default
You and your supercharger plans......
You aren't going to swap to a MP2 or MP3 when you supercharge it?
Twin_Cam is offline
Old 05-24-2004, 05:07 PM   #17
TheSaturnKid
Default
Nope. Im just going to see how long the auto will last under boost, as well as the stock engine. The only preventative action I will take is not putting it in perf. mode and adding a bigger tranny cooler---> Going in this weekend.
I can get it tuned pretty damn well with the emanage. The emanage will completely take over ignition duties and will drive two extra injectors.
And an MP2 is pointless for boosting w/ an s/c. Its only good for a turbo application.
With an s/c, you make peak boost at redline. If you had an MP2, its just a longer period to wait until you make peak boost. With a turbo, you can make peak boost (depending on the setup) from 4K to redline. This merits an MP2 as you will be able to hold peak boost for a longer period of time.
I just moved back to Ohio and I just got a new job. I should be boosted before the summer is over.
Old 05-24-2004, 08:34 PM   #18
Red97sc2
Red97sc2's Avatar
2001 SL2
2005 ION-2 Sedan
Default
You better! I want to test drive "my" future mods as well
2008 Nissan Altima
2005 Subaru Impreza
2003 Grand Marquis
Red97sc2 is offline
Old 05-24-2004, 10:15 PM   #19
TheSaturnKid
Default
You break you buy.
The old chinese addage.
Old 05-27-2004, 08:18 AM   #20
chrispel
chrispel's Avatar
2001 SL2
Default
I felt some vibration but less then what I feel from the twistec mounts until they break-in then you only feel it a little.
98 SC2 DP Nitrous
chrispel is offline
Motor mounts?? lubers S-Series General 15 04-27-2005 10:48 PM
My motor mounts? Turbosdime18 S-Series General 10 03-03-2005 08:26 PM
WTT: SPS Motor Mounts for Stock Motor Mounts soccer69er Classifieds 1 10-28-2004 07:13 PM
motor mounts 92saturnsl2 S-Series Tech 9 08-12-2002 01:08 AM
Motor Mounts Spanky Miscellaneous Tech 6 02-23-2002 07:00 PM
