Old 05-04-2020, 08:16 PM   #1
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Backup lights...
Reverse lights not working...
I checked the bulbs, no power...
I checked the switch (manual transmission), I have voltage.
I ohmed the switch, I have continuity across the switch...
Lost...
What now?
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 05-04-2020, 09:24 PM   #2
SRGW
1997 SL1
Post Re: Backup lights...
Maybe this will help?
1995 SL1 236,300 2005>2018
1997 SL1 83,050 2014>????
CHECK YOUR OIL!!
Old 05-05-2020, 01:29 PM   #3
bluesl2
bluesl2's Avatar
Default Re: Backup lights...
Do you have voltage coming out of the switch or just going in?
Old 05-05-2020, 02:55 PM   #4
Waiex191
Waiex191's Avatar
The backup lights on my 98 have never worked since I've owned it. If I pop the connector off the shift tower switch and short the harness conductors together, they come on. I bought a new switch but no joy. Not much help, sorry.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-05-2020, 04:16 PM   #5
mattwithcats
Wrench Re: Backup lights...
I think the problem lies in the UHJB (fusebox)...
According to the diagram,
power goes to the fuse,
then to the switch,
then BACK to the fusebox,
then to the backup lights...
I think if you check, you have power going into the fusebox, the second time,
but NOT out to the backup lights...
Options, opinions?
I think removing the jumper, and adding a second fuse to the fusebox, may be the best move...
Old 05-05-2020, 04:33 PM   #6
toggenburg
toggenburg's Avatar
Gotta then check for broken wire that commonly feeds both reverse bulbs, OR really make sure that both bulbs are GOOD and not having a dangling filament.
Running cable for backup camera & tapping into reverse lights for backup sensors shaxs Vue General 19 08-02-2018 02:07 PM
Brake lights, backup lights out mjmcginty 2008 Vue 9 06-29-2016 10:48 PM
Backup lights help Linus S-Series Tech 9 03-18-2015 10:25 AM
No Backup Lights blackbeard S-Series Tech 4 01-13-2014 10:23 AM
01 SC2 No backup lights Photoweborama S-Series Tech 3 03-15-2013 07:29 PM
