Old 04-19-2020, 10:05 PM   #1
Gstan36264
Gstan36264 is on a distinguished road
2007 AURA XR
Default DIC Life of Oil %
My 2007 Aura XR with 158 k. I can't get the oil life to reset to %100. Nor can I enter the DIC Vehicle Personalization. I can reset the trip meters and scroll through the rest of the information but no resetting or changing. I disconnected the battery for a few minutes and pulled the ECM fuses but to no avail.
Thanks for any help that may be forthcoming.
Gstan36264 is offline   Reply With Quote
Old 04-20-2020, 06:49 AM   #2
imaddicted2u
imaddicted2u's Avatar
2008 AURA XE
Default Re: DIC Life of Oil %
To reset oil life...
Scroll DIC to Oil Life...Key to ON, Don't start...press gas pedal to floor 3 times.
Old 04-20-2020, 06:52 AM   #3
imaddicted2u
2008 AURA XE
Your vehicle has personalization capabilities that allow
you to program certain features to a preferred setting.
All of the features listed may not be available on
your vehicle. Only the features available will be
displayed on the DIC.
The default settings for the features were set when your
vehicle left the factory, but may have been changed
from their default state since that time.
To change feature settings, use the following procedure:
Entering Personalization Menu
1. Turn the ignition on while the vehicle is stopped.
To avoid excessive drain on the battery, it is
recommended that the headlamps are turned off.
2. Press and hold the information and reset buttons at
the same time for one second, then release to enter
the personalization menu.
If the vehicle speed is greater than 2 mph (3 km/h),
only the UNITS menu will be accessible.
3. Press the information button to scroll through the
available personalization menu modes.
Press the reset button to scroll through the available
settings for each mode.
If you do not make a selection within ten seconds,
the display will go back to the previous information
displayed.
Old 04-20-2020, 06:57 AM   #4
imaddicted2u
2008 AURA XE
How to Reset the Engine Oil Life
System
The Engine Oil Life System calculates when to change
the engine oil and filter based on vehicle use. Whenever
the oil is changed, reset the system so it can calculate
when the next oil change is required. If a situation occurs
where you change the oil prior to a CHANGE OIL SOON
message being turned on, reset the system.
After changing the engine oil and filter, the system must
be reset. To reset the oil life system:
1. Turn the ignition key to ON/RUN with the
engine off.
2. Fully press and release the accelerator pedal
three times within five seconds.
If the message is not displayed, the system is reset.
If the CHANGE OIL SOON message comes back
on when you start your vehicle, the engine oil life system
has not reset. Repeat the procedure.
Old 04-20-2020, 09:35 AM   #5
Gstan36264
2007 AURA XR
Thanks, I'll try it.
Old 04-20-2020, 09:40 AM   #6
Gstan36264
2007 AURA XR
Thanks, everyone.
Old 04-20-2020, 09:42 AM   #7
Gstan36264
2007 AURA XR
System
engine off.
Thanks, that's the kind of stuff I'm looking for.
Old 04-20-2020, 12:01 PM   #8
imaddicted2u
2008 AURA XE
Here is a copy of the Owner's manual...
https://my.gm.com/content/dam/gmowne...ura_owners.pdf
Old 04-20-2020, 09:37 PM   #9
Gstan36264
2007 AURA XR
Thanks for the help, mashing the pedal three times did the trick. Oil % is now 100.
CPS life xserver S-Series Tech 2 04-23-2013 02:46 PM
Is A "Sealed For Life" ManTransmission Really Sealed For Life? sl1driver S-Series Tech 26 01-27-2011 03:17 AM
A/C Life DonP S-Series Tech 8 08-18-2009 10:21 PM
CAT Life DonP S-Series Tech 5 11-26-2008 03:58 PM
New life for my old SL2 James1549 S-Series General 2 02-16-2004 04:20 AM
