Old 03-25-2019, 05:08 PM   #1
JosephN79
JosephN79 is on a distinguished road
JosephN79's Avatar
2004 VUE Red Line
Default High Beams Stay On
I took my Saturn out today, itís been sitting a few weeks.
I come home and notice after a half hour the high beams are still on. They stay on regardless of if ignition is off or on, if I pull the parking brake. If I turn lights off and on they do so, as well as turn signals. The high beams never go off.
I read that it could be the ďclickerĒ or stalk needs replaced. I already have it out, it would be super easy to replace.
The article I read was on an SL1, and never got any closure from the OP of a new switch worked, or any resolution for that matter.
Also, pulled the DRL relay and that didnít turn them off, just a stab.
Thanks for any help!
JosephN79 is offline   Reply With Quote
Old 03-25-2019, 05:16 PM   #2
JosephN79
JosephN79's Avatar
2004 VUE Red Line
Default Re: High Beams Stay On
Soooo, anyway.
I disconnected the battery and the lights went off. I figured Iíll put it pack on real fast and see if they come back on. They didnít come back on. I hooked everything back up and everything works as it should.
Iím a little gun shy after owning this guy for the past 6 years, so Iím still guarded. Lol. Could my switch be going bad?
Old 03-26-2019, 10:12 AM   #3
far2grumpy
far2grumpy's Avatar
One side of headlamps are "hard-wired" to battery (thru fuses).
Possible causes of high beams staying on:
1. Ground side wire of lighting circuit intermittently shorted to ground or one of following keeping ground applied.
2. Sticky HEAD LAMP Relay (part of auto headlight system - I/P fuse block).
3. Lighting stalk problem - either high-beam activation or flash-to-pass.
4. Internal BCM problem.
I try to visit forum often but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 03-26-2019, 07:31 PM   #4
JosephN79
JosephN79's Avatar
2004 VUE Red Line
Hmmm.. itís all good still since I disconnected/reconnected the battery cable. Hopefully just one of those things and I wonít have to deal with it til later. 👀
2006 Saturn Ion 2 - High Beams Work, Low Beams Do Not. spacer7767 Ion General 4 10-31-2018 07:44 AM
High Beams will not stay on after clicked bachands S-Series General 9 07-30-2015 05:29 AM
High Beams indicator flickering, cutting DRLs, but no high beams andymcconnell L-Series Tech 6 10-04-2012 10:14 PM
Low beams stay on Smokeater S-Series Tech 3 12-16-2011 12:04 PM
Fog lights to stay on when high beams are on Dave19yz S-Series Tech 12 12-26-2007 06:46 PM
