Old 08-13-2002, 02:50 AM   #1
Beaker
Beaker is on a distinguished road
Question Throttle Response
I posted this on another "Saturn" Message board but I think they were too busy asking about Altezza tail lights and 19 inch rims to understand, let alone answer the question.
Due to a wearing steering rack in my CRX, I've been splitting the duties recently between the Rex and the Satty, and everytime I get in the Saturn I notice the response to pressing the accelerator is like pushing my foot into a undercooked piece of cake. Just mush, no response. Now the plugs and wires are pretty new, so I don't believe it to an ignition problem, is it possible my pedal is just sitting low, or do I need to tighten my throttle cable?
Beaker is offline
Old 08-13-2002, 09:35 PM   #2
wolfman
wolfman's Avatar
Default
Depending on the year/model/trans type of the Saturn it could simply be the power difference you are noticing. Pre-95' SL-1 Saturns had throttle body injection and as little as 85 HP. If the car performed better in the past and is showing no SES light then the primary suspect would be a clogged fuel filter and or dirty throttle body or fuel injector(s). After that a faulty throttle position sensor could be the cause of your problem as well.
wolfman is offline
Old 08-13-2002, 10:03 PM   #3
Phil
Phil is on a distinguished road
Default
You know, some Altezza lights would add 10hp at the wheels.
But seriously, what kind of Saturn is it? What kind of tranny, are you running the A/C, is the fuel mileage suspiciously horrible?
Phil is offline
Old 08-13-2002, 10:06 PM   #4
PFY
PFY is on a distinguished road
Default
I get the exact same feel from my '97 SL2, just no UMPH ya know? Mine is an automatic, so i really blame the torque converter, but i am going to have the fuel filter replaced soon, as it's been about 50k since i've done it.
PFY
PFY is offline
Old 08-13-2002, 11:12 PM   #5
Beaker
Thumbs Up
ok, sorry I didn't give the vital info guys. It's a 91 DOHC, 5 sp, port & polished head, 8mm wires, and intake. By throttle Response I don't mean the car is slow. Honestly, as much as it kills me to say it, it whipes the floor with my CRX. What I mean is even under no strain, clutch pressed, when I stab the throttle it hesitates. There should be no bogging, because theres no load to carry, even out of gear, it dies for a second then takes off, I have no idea why. Any help would be appreciated. oh yeah, and it never does it after the initial stab at the throttle, it on;y does it when going from completely off the throttle to on.
Beaker is offline
Old 08-13-2002, 11:28 PM   #6
Default
Do a check on all the basics to make sure that everything is up to par before getting to far into other things. Check the secondary ignition system, plugs, wires, coils. Has it been awhile since the fuel filter has been changed?
ssicarman is offline
Old 08-14-2002, 04:44 AM   #7
Heartbeat - '95 SL2
Heartbeat - '95 SL2 is on a distinguished road
Heartbeat - '95 SL2's Avatar
Default
Maybe start with seeing if any codes are set. If not the throttle position sensor, it could be something wrong with the idle air control? Doesn't that control air/fuel ratio at idle as well as partial throttle? When you replaced the wires, did you check for corrosion on the coil pack terminals? How long since you replaced the O2 sensor? Possibly a clogged catalytic converter? Just throwin' out ideas.
Heartbeat - '95 SL2 is offline
Old 08-14-2002, 07:19 AM   #8
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Idea
Another idea is to check the EGR valve. When the EGR valve begins failing we get slightly worse acceleration, worse gasoline mileage, and the car sort of "bucks" and "stumbles" when coasting/idling from a stop in first gear. If the EGR valve is still original this is where I'd place my bet. Nah, I'll place my bet on the EGR valve (and/or its solenoid) anyway!
David 93 SL2m is offline
Old 08-14-2002, 12:34 PM   #9
Terrandus
Terrandus is on a distinguished road
Terrandus's Avatar
Default
My 1996 SL1 used it hesitate on me all the time, it gets kinda scary when your trying to cross four lanes of traffic in rush-hour. At that time I had 75k miles on it and someone here recommended that I change the fuel filter I did that and the egine is back to running just fine.
Terrandus is offline
Old 08-14-2002, 01:07 PM   #10
93BLKTWINCAM
93BLKTWINCAM is on a distinguished road
2001 SW2
2004 ION Red Line
Default
On the wife's '94 SC1 single cam, I have a major problem with pick-up. I tuned and changed/swapped all the stuff that could cause the general lack of power. I was told by a friend/professional mechanic that the guide(s) are broken on the chain and that the timing is off. I was told by wolfman that this is not the case. All I can say is that the single cam in this car ****s. I purchased the vehicle used, and it hasn't improved much over the 3 years that we owned it. Can anything else be causing such a lack of general power?...
93BLKTWINCAM is offline
Old 08-14-2002, 04:51 PM   #11
Terrandus
Terrandus's Avatar
Default
How much of a lack in power? Blown Head gasket? or maybe something thats causeing you to loose compression?
Old 08-14-2002, 10:13 PM   #12
93BLKTWINCAM
2001 SW2
2004 ION Red Line
Default
I did a little checking and it seems that the EGR is not functioning. I put a vacuum pump on the diaphram and it will hold vacuum but it won't pull the plunger up. If I pull it up manually, the engine kills. Also, I noticed in open loop (cold engine) that the car runs a bit better, but when 1/4 or more on the temp., the car doesn't perform as well. With the a/c on, it can't get out of it's way. Would the EGR cause a general loss of power if not opening?...
Old 08-14-2002, 10:28 PM   #13
Default
The EGR should open when vacumm is put to it when the engine is not running. When it is runnng there is a vacumm bleed so that the EGR does not open to fast and cause a stumble. Your vacumm pump may not be able to give it enough vacumm flow with the engine running to open the EGR. If the EGR won't open under vacumm with engine off then there is something wrong.
Old 08-14-2002, 10:35 PM   #14
93BLKTWINCAM
2001 SW2
2004 ION Red Line
Default
Would that cause a "bogg" when taking off? Would the EGR not functioning cause a general lack of power?
Old 08-14-2002, 10:36 PM   #15
wolfman
wolfman's Avatar
Default
The loss of EGR activity genearally alone will not cause a loss of power unless it is increasing detonation/spark knock and bringing the knock sensor ignition retard into play. HOWEVER, EGR valves rarely just "suddenly" fail but get gradually lazy until they just cease to open. This can allow build up under the valve closing point preventing complete sealing. If indeed the valve is bad replacing it should provide a noticable improvement regardless of which issue it is manifesting. Also remember if your 94' SC 1 has the throttle body injection it is rated somwhere around 85-90 hp NEW, thusly it will not have near the power of a "2" car with 124 hp.
wolfman is offline
Old 08-14-2002, 10:40 PM   #16
93BLKTWINCAM
2001 SW2
2004 ION Red Line
Default
I didn't know how good a single cam Saturn ran until my brother-in-law purchased his '95 and took me for a ride in it. It runs pretty close with my twin. I know the '95s had 100 hp rating which is a little more than the 85 or so hp of the '94...
How about open loop running vs. closed loop. Where does the temp. have to be to enter closed loop?...
Old 08-14-2002, 11:04 PM   #17
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Cool
Do I win a prize?
Check for computer codes with the paperclip trick. I bet you see a 34...
Changing the EGR valve is easy and it comes with a new gasket. It is about $50 for a new EGR valve for the old Saturns.
Old 08-15-2002, 12:10 AM   #18
93BLKTWINCAM
2001 SW2
2004 ION Red Line
Default
This EGR doesn't open under vacuum. The diaphram seems ok, but it doesn't raise the valve from it's seat. If it's closed all the time, how would the engine respond?...
My brother-in-laws Saturn loss the brakes when his EGR stuck open. The car would barely run and when the EGR was replaced, his car ran like a spooked deer...
Old 08-15-2002, 08:28 AM   #19
David 93 SL2m
2004 VUE 2.2L
2007 ION-3 Sedan
Attention
Ooops! I meant to write code 32. Sorry, I made a mistake.
Old 08-16-2002, 02:05 PM   #20
Terrandus
Terrandus's Avatar
Default
OFF TOPIC:
I keep hearing about this paper clip thing to read the error codes, perhaps someone could point in the direction where I can find out exactly how to do this, it beats having to pay my dealer 30$ to give me the same info....
Odd throttle response 94 SW1 groingo S-Series Tech 0 11-28-2009 10:13 PM
Bog down/Surge throttle response JonP S-Series Tech 2 03-28-2009 12:00 PM
Is throttle response different from horspower? sl2gold S-Series General 22 06-30-2007 08:42 PM
throttle response? irondiezl3 S-Series Tech 3 12-11-2006 01:05 AM
Throttle Response Son93SL2 General Saturn Discussion 6 04-19-2001 11:34 PM
