Old 11-03-2018, 11:55 PM   #1
mbr
mbr will become famous soon enough
1998 SW2
Default War on tailgaters.
No matter what speed I go, I'm always tailgated. At or over the speed limit. Don't tell me to speed up or pull over, ain't gonna happen.
I had this made a few months ago. Tailgating went from always to rarely. When they pull up close behind me, they immediately drop back.
I also have a pair of small flashing strobes I was going to mount at the back with a switch under the dash, to blind the a-holes if they don't drop back, but so far don't see the need.
File Type: jpg 38612552_10215101111859254_1344586103818027008_o.jpg (155.9 KB, 56 views)
Accuracy MATTERS!
mbr is offline   Reply With Quote
Old 11-04-2018, 08:53 AM   #2
onlinebiker
Default Re: War on tailgaters.
I had a 87 Chevy 3/4 ton that I used for hauling my sailboat.
I beefed up the frame with 3/16 steel plate cutouts, and made the bumper out of 5 1/2 inch schedule 40 tubing on front and back.
I painted in letters which followed the pipe curvature, so they appeared from the rear as the full thickness of the bumper - which read -
Tailgate? Your funeral.
People kept a respectful distance for the most part.
93 SC2
96 SC2
97 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-04-2018, 09:28 AM   #3
bumpdraft
bumpdraft's Avatar
1998 SW2
They do not even know they are too close, as difficult as it is for sane, rational people to understand...
Anything you do will be received as waking them from a nap.
The best thing to do is film out the back window and fill a storage device with footage.
You can’t stop it. — Collision shoppes beam CIA radio waves that are received by the mentally weak.
(New cars have really good brakes and drivers have adjusted their following distance accordingly )
Old 11-04-2018, 09:38 AM   #4
Windshield washer nozzles mounted on the rear, either reposition the rear wiper nozzle on the Wagons or run a custom setup.
If the car is cheap enough or you just don't care...take the Deboss Garage way: https://www.youtube.com/watch?v=OHcemu3Llis
Old 11-04-2018, 10:50 AM   #5
mbr
1998 SW2
I have considered more extreme measures, like putting nozzles at the rear that shoots out old motor oil, and tossing rocks out the window. But in a state where any nut job can carry a concealed gun without a permit, I wouldn't want to find out who's crazier. Or worse, it might be an off-duty cop.
Accuracy MATTERS!
Old 11-04-2018, 11:04 AM   #6
cgg17
cgg17 is just really nicecgg17 is just really nicecgg17 is just really nicecgg17 is just really nice
cgg17's Avatar
I drive about 5 faster, get some distance, then put my brake lights on. I touch the brake just until the lights come on but no braking occurs. Then i keep driving. If they continue to tailgate i slow down more. If they try to pass i go back to the speed limit. Normally they either slow down when my brake lights are on, expecting a brake check or theh try to pass.
1999 Sl2 4spd: 98,8xx
Old 11-04-2018, 12:12 PM   #7
bumpdraft
bumpdraft's Avatar
1998 SW2
But, you want them to pass Not passing is the problem. I want them to pass at 30mph over the speed limit and I want them to continue to hold their acelerator to the floor until they disappear over the horizon or reach fuel cut-off. Whichever comes first.
IF they are not able to pass, then they should remember that the white lines are 10 feet long, and the space between is 30 feet. One car length following-distance for every 10 mph
Old 11-04-2018, 01:10 PM   #8
bumpdraft
bumpdraft's Avatar
1998 SW2
You won’t need an oil sprayer if you let me try to rebuild your rack and pinion
I would not think an off-duty officer would tailgate for no apparent reason.
IF you suspect that off-duty officers are tailgatig you, while you’re at, or 5 over, the posted limit, then you need to have a calm sit-down meeting with the Cheif of Police.
Meanwhile, get a video recorder.
Old 11-04-2018, 04:54 PM   #9
herp444
herp444 is on a distinguished road
herp444's Avatar
2008 SKY Red Line
I had a boss many years ago who commuted to work everyday. it was one hour each way highway. I don't recommend it but he cut a hole in the floor of the car and made a trap door. when people would tailgate him he would just grab a handful of bb's and start dropping them down. he said it didn't take long for them to back off
herp444 is offline   Reply With Quote
Old 11-05-2018, 09:15 AM   #10
bumpdraft
bumpdraft's Avatar
1998 SW2
That was before ubiquitous mass surveilance.
What you want is a video recorder to start building your defense case before anything happens. If you’re an insider, and part of a harassment mob, then you already have protectionand don’t need video
P.S.—There is no war on tailgaters. Tailgaters won a long time ago.
Old 11-05-2018, 09:37 AM   #11
dummo
dummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to alldummo is a name known to all
dummo's Avatar
^^^^LOL.
What sucks about Tailgaters is that many are too stupid to pass you on the left like they should (rural single-lane road). One passed me on the right at a 4-way stop today so both of us went through the intersection at the same time.
Ignoring them seems to work the best. Makes the fun last longer - like pulling a band-aid off slowly. although I have considered some kind of a flip down black out piece for my rear view mirror. Maybe with a inspirational message written on it.
The best so far was a bumper sticker I saw... "Sorry for driving so closely in front of you"
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Old 11-05-2018, 10:36 AM   #12
Or (preferably) they get pulled over by a very irritable state trooper.
There's a great scene at the end of Raising Arizona where the boss, Glenn, is always trying to tell a Polack joke. He's pulled over and tries to tell the joke to the trooper to ease the situation. Camera pulls back and you see the name Jablonski (or similar) on the trooper's badge as he is writing the ticket
Old 11-05-2018, 10:42 AM   #13
dummo
dummo's Avatar
Just remember, it's not you. When these guys get past you (whether you politely pull over or they get by you using the right lane), they will be for certainty seen ahead riding the next driver's rear bumper.
Old 11-05-2018, 12:04 PM   #14
cgg17
cgg17's Avatar
A handful of rust would be great to drop through the floor pan
Old 11-05-2018, 05:17 PM   #15
Buddy of mine got in trouble for pointing a BB gun out the window and taking a shot. Wasn't even aiming but managed to hit the windshield. Think he just got a fine and probation, no jail time (or maybe just a short stint).
This is not a recommendation / suggestion, but it seems like it would be easy to fit a small box in the rear fender, behind the fender liner. A small pull wire could pull the liner enough to slowly release any gravel, sand, etc., that was in there. Said gravel would be rolled over by the rear tire and spray any tail-gaters
Old 11-05-2018, 09:08 PM   #16
dummo
dummo's Avatar
...or a pet skunk in the trunk that could be trained to spray into a second dummy tailpipe. You could have fun all day with that setup.
Old 11-05-2018, 09:14 PM   #17
bumpdraft
bumpdraft's Avatar
1998 SW2
Are you suggesting...skunk junk in the trunk? I believe you are!
Old 11-05-2018, 09:17 PM   #18
dummo
dummo's Avatar
Yes, but you have to keep moving forward.
Tailgaters can go you know where! saturnd-KC General Saturn Discussion 21 08-28-2001 04:30 PM
