Old 07-20-2009, 07:36 AM   #1
PCF
PCF is just really nicePCF is just really nicePCF is just really nicePCF is just really nice
PCF's Avatar
2004 VUE 2.2L
2005 VUE 2.2L
Dizzy Clicking when turning left
After buttoning up my daughter's 2000 SL2 with a replaced passenger side driveshaft and oil pan, now we are starting to hear a slight clicking sound when turning left and applying power.
I'd say this means I have to replace the driver's side axle shaft/CV joints, just wanted to confirm with you folks. Sounds like I also have to replace the transaxle fluid as well.
Am I correct?
2005 Vue 2.2L FWD 5 speed
PCF is offline   Reply With Quote
Old 07-20-2009, 04:38 PM   #2
01SuperCoupe
01SuperCoupe is on a distinguished road
2009 Astra XR
Default Re: Clicking when turning left
If it's only a slight clicking noise you may be able to just replace the CV boot and grease. Did you check the boot in question to see if it was damaged/torn? I've only had a clicking CV shaft twice in all my years with FWD cars, once I was able to just replace the boot and repack it with grease, the other time the damage was so bad I had to replace the whole shaft and CV assembly.
01SuperCoupe is offline   Reply With Quote
Old 07-21-2009, 11:15 AM   #3
PCF
PCF's Avatar
2004 VUE 2.2L
2005 VUE 2.2L
The boots are in good shape, I had this shaft out of the car last week when I thought I was going to have to pull the transmission.
Unless others here can suggest something else, I think I'll end up replacing the entire shaft and CV joints with a new one. $50.79 from Rock Auto. The car has 180,000 miles on it!
Old 07-21-2009, 11:21 AM   #4
I got my axles for $14 (already removed from the car) from August Pohl (junkyard) in Benton Harbor, MI. Depending on where you are in NW IN, might be worth a drive, or maybe find comparable used ones near you by using www.car-part.com
OldNuc's written a couple of times on how to test them before buying. I can find one of them by searching under my user name if you're interested (search for "replace" in the thread title; I had a torn boot and asked about repairing or replacing)
Old 07-23-2009, 10:30 AM   #5
PCF
PCF's Avatar
2004 VUE 2.2L
2005 VUE 2.2L
Bump
Any ideas or confirmation of my diagnosis or solution?
Old 07-24-2009, 06:56 AM   #6
BarnOwl
BarnOwl's Avatar
2000 SW2
One easy thing to check. Look at the passenger side wheel well at the brake line. It should curve to the rear of the car. It's possible that you twisted it to the front. If you did, it's an easy fix.
Blasted clicking noise when turning keonato S-Series Tech 7 12-27-2009 12:32 AM
Clicking noise when turning the wheel while backing up j2s2why Outlook General 3 09-05-2007 12:40 AM
Knocking rubbing clicking when turning schorch Ion Tech 4 03-16-2007 01:10 PM
grinding noise when turning left defy69 Ion General 1 11-29-2006 04:32 AM
Issue while turning left tosil S-Series Tech 2 02-06-2006 04:53 PM
