Old 09-16-2012, 03:57 PM   #1
edefisio
edefisio is on a distinguished road
Default changed ECTS now temp guage not woorking
I just changed the engine coolant temperature sensor on my 2002 SL2, due to intermittently not starting and based on several posts here. After i changed it, the SES light came on and now the temp guage is not moving at all, though the car did start and seems to be running normal enough. The connector looked to be in good shape, in fact i didn't see any visible problems with the original ects upon removal. Any ideas?
Add to edefisio's Reputation
Rate the quality of this post and help edefisio reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
edefisio is offline   Reply With Quote
Old 09-16-2012, 06:27 PM   #2
campus189
campus189 is on a distinguished road
campus189's Avatar
1997 SL1
Default Re: changed ECTS now temp guage not woorking
I take it you visually inspected the connector well?
Are the wires spliced or have electrical tape on them?
1997 Saturn SL2 144,000 Miles
1997 Saturn SL1 254,000 Miles
1997 Saturn SL1 157,000 Miles
1996 Saturn SL1 97,000 Miles
Also known as FiremanCV on YouTube
Add to campus189's Reputation
Rate the quality of this post and help campus189 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
campus189 is offline   Reply With Quote
Old 09-16-2012, 07:07 PM   #3
edefisio
Hi, thanks for the reply...
yes the connector looked fine. no corrosion or anything abnormal.
no electrical tape or signs that it has been replaced before.
The first time I started the car after replacing the sensor, the temp guage pegged all the way to the right for about 15 seconds, then it dropped all the way to the left and the "service engine soon" light came on. and that is where it is stuck at.
is it possible that i got a bad sensor from the auto parts store? I also tried flipping the connector 180 degrees in case that was a problem, and it seemed to snap into place fine, but no change in the gauge.
thanks for any ideas you may have.
Old 09-16-2012, 08:11 PM   #4
magtec
magtec will become famous soon enough
1995 SW2
yeah.
Add to magtec's Reputation
Rate the quality of this post and help magtec reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
magtec is offline   Reply With Quote
Old 09-16-2012, 08:15 PM   #5
dakota1820
dakota1820 will become famous soon enough
2002 SL
1995 SL2
could have broke the tip loose from the brass portion of the sensor
Add to dakota1820's Reputation
Rate the quality of this post and help dakota1820 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dakota1820 is offline   Reply With Quote
Old 09-17-2012, 07:22 AM   #6
DonP
1995 SL2
You also could have received the wrong sensor (not an ECTS).
The 2002 should have had the brass tip ECTS and that is an unlikely failure.
What codes are set?
Add to DonP's Reputation
Rate the quality of this post and help DonP reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Temp Gauge Was In The Red Today...Just Changed ECTS BassHypnotist S-Series General 11 03-30-2012 11:07 AM
06 2.4L, temp guage at zero briansnoopy Ion Tech 7 04-19-2006 09:49 PM
wiring outside temp guage 94SL2ndOwner S-Series Tech 8 05-14-2005 04:42 PM
Outside Temp Guage 94SL2ndOwner S-Series General 0 05-06-2005 02:02 PM
HELP!! Glow face guage install! Temp guage error! SpeedySL1 Suggestion Box 2 04-01-2004 04:05 PM
