Old 09-12-2006, 02:32 PM   #1
Moose1198
Moose1198 is on a distinguished road
Default Motor question: 96 DOHC head on a 92 SOHC Block
So i have a 96 SC2 that has a spun rod bearing or such in the bottom half of the motor. 88k on the odometer.
I've found a motor out of a 92 SL1 that has low milage for $150 locally. I know that Saturn kept the block the same until 98; however, does anyone here have any idea on where i might find hangups on mating my good 96 head to this good 92 block? I'm sure the compression ratio's are different among other things. They somehow cranked 40 more hp out of the DOHC motor with the same lower end of the motor so I'm curious how and if it would be a possibility to do this ******* mating to save myself money on fixing this car.
Any help would be greatly appreciated Thanks
Moose1198 is offline   Reply With Quote
Old 09-12-2006, 03:12 PM   #2
Dr B
Dr B is on a distinguished road
Dr B's Avatar
1992 SL2
1993 SL2
Default Re: Motor question: 96 DOHC head on a 92 SOHC Block
The 92 crankshaft is not compatible with your 96 ,because of the C P S
trigger,.!
Otherwise the swap would probably go ,
however the crank is what you mainly need ,with spun bearing & all !
Have A Great Day , it is YOUR choice !
Dr B is offline   Reply With Quote
Old 09-12-2006, 04:14 PM   #3
Moose1198
cps = crank position sensor?
the tech at saturn told me the crankshafts were the same.. but they changed the sensors? weak
Old 09-12-2006, 04:27 PM   #4
WingsOfSaturn
WingsOfSaturn's Avatar
different crank in the 91-92 block. stay away from it, too many headaches.
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
Old 09-12-2006, 05:48 PM   #5
Monkius
Monkius is on a distinguished road
Monkius's Avatar
1998 SW2
why don't you just replace the rod bearing? Especially with an engine with fairly low mileage... It's not hard, I've done it in my driveway...
Monkius is offline   Reply With Quote
Old 09-12-2006, 09:17 PM   #6
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
Does the SOHC not have dished pistons for lower compression? It will hurt your horsepower, if so.
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
bennett9000 is offline   Reply With Quote
Old 09-13-2006, 12:10 AM   #7
PACT Man
PACT Man is on a distinguished road
PACT Man's Avatar
1995 SC1
What is a crank bearing was spun? And once you spin a bearing if you replace it it will just spin the next one unless you have all the journals bored out and honed and redone. I'm actually in the process of swapping blocks on my brother's Civic after he spun a bearing.
I want to go fast!!!
PACT Man is offline   Reply With Quote
Old 09-13-2006, 10:55 AM   #8
Monkius
Monkius's Avatar
1998 SW2
I guess mine wasn't quite "spun" then... It was still making the rod knocking noise, though... It's been a year, easily since we fixed it, and it's still not making any noise (leading me to believe it hasn't spun the next one).
DOHC head bolt to a SOHC block toussaint_89 S-Series Mods 1 02-22-2008 10:52 PM
01 DOHC on 97 SOHC BLOCK?? Saturntrip S-Series Tech 8 02-20-2008 02:25 AM
99 dohc heads on 96 sohc block youngrenton S-Series Tech 3 08-07-2007 08:10 PM
DOHC on a SOHC block? corey-c S-Series Tech 4 04-24-2006 06:53 AM
DOHC vs SOHC block, rods etc etc jasonsl2 S-Series General 1 02-17-2005 09:22 PM
