Old 02-13-2006, 09:13 AM   #1
softspot
softspot is on a distinguished road
1997 SL1
Sad code 26 saturn sl1 94
I have code 26 showing up and i know it is Quad drive, but what i need to know what is best way to test ,egr solenoid, and evac solenoid , i was told that one or both of these could be problem. thanks. car runs great but just this dam code engine service light stays on after start.
softspot is offline   Reply With Quote
Old 02-13-2006, 11:32 AM   #2
poorboy
poorboy is on a distinguished road
Default Re: code 26 saturn sl1 94
Here's a flowchart from Differentracing.com
http://www.differentracing.com/tech_...es/dtc/26.html
HTH
94 SL2 Automatic
poorboy is offline   Reply With Quote
Old 02-13-2006, 11:58 AM   #3
charcoal
charcoal is on a distinguished road
1993 SC2
Fairly easy checks as referenced by differentracing.
I had some difficulty getting a good connection into the terminals of the EGR solenoid connnector [while on the car] for measuring the coil resistance.
The best results occured with the solenoid out of the car and on the bench for a careful measurement and power-applied functional check.
Search the forum using the search engine for more information and tips.
charcoal
charcoal is offline   Reply With Quote
Old 02-13-2006, 01:57 PM   #4
RangerRover
RangerRover is on a distinguished road
RangerRover's Avatar
1999 SW2
I had this exact problem - it turned out that the plug on the solenoid had fallen off (the small part that is attached on the right hand side of the valve cover) because the clip broke. I re-attached it using zip ties. No problem since. I would start by checking that...
RangerRover is offline   Reply With Quote
02 Saturn sl1 p0410 code FearsOfWar S-Series Tech 8 12-11-2009 04:01 AM
1994 saturn sl1 code 26. help please softspot S-Series Tech 4 02-11-2006 08:19 PM
1995 Saturn SL1 Error Code 24 Seres S-Series General 5 12-31-2005 04:37 AM
Saturn SL1 Code Reset Javert1997 S-Series General 7 12-28-2005 06:21 PM
92 SL1 Code 26 chshoo S-Series General 2 01-06-2005 08:15 AM
