Old 02-11-2006, 12:39 PM   #1
softspot
softspot is on a distinguished road
1997 SL1
Attention 1994 saturn sl1 code 26. help please
I have had my saturn short time bought used cept maitance up , but just had serve engine linght came on , got code 26 , when to saturn and had the anilize all sensor checked ok, suggested cleaning egr, but have problem , with cooling fan not coming on with a/c. and car sum times after startin can detect gas or rotin egg smell , have purchased ets sensor and new connector, witch i will replace tommorrow see what happens. let yah . know . thanks for any in put.
softspot is offline   Reply With Quote
Old 02-11-2006, 01:15 PM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: 1994 saturn sl1 code 26. help please
Does the cooling fan come on when you turn on the A/C? If not, then its probably the cooling fan relay and thats why you are seeing the code 26. But by your description, sounds like you may have multiple problems.
BTW, more info here:
http://www.differentracing.com/tech_...dtc_chart.html
Click on code 26.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 02-11-2006, 05:54 PM   #3
Saturn-Eh!
Saturn-Eh!'s Avatar
26 is a quad driver fault, and is most often caused by aging egr and canister purge solenoids. The only way to tell for sure is to measure resistance across the connector terminals when hot.
I just replace them on an older car with that code - Unless, there is something else on the quad driver circuit whic is malfunctioning - upshift lamp, ac compressor, cooling fan etc...
Saturn-Eh! is offline   Reply With Quote
Old 02-11-2006, 06:36 PM   #4
Flyin
Flyin is on a distinguished road
The rotten egg smell is usually a plugged catalytic converter.
Flyin is offline   Reply With Quote
Old 02-11-2006, 08:19 PM   #5
Saturn-Eh!
Saturn-Eh!'s Avatar
sulfur/Rotten egg smell is sullfur content in gasoline. a plugged cat doesn't smell like anything...
Sulfur smell is most prevalent in newer catalytics, and at "second tier" gas stations where the refining process isn't as great at removing sulfur.
Saturn SL1 1994 AnthonyL S-Series General 3 10-05-2009 09:42 AM
1994 Saturn SL1 Gets really hot.... Dserge S-Series General 20 07-28-2007 10:35 PM
1994 Saturn SL1 Seatbelt Question unibrain S-Series General 14 11-07-2006 02:37 PM
1994 Saturn SC1 EGR valve malfunction trouble code Dingo Warrior S-Series Tech 2 02-26-2006 02:31 PM
1994 Saturn SL1 saturn_h8r S-Series General 4 07-06-2004 12:25 PM
