Old 09-24-2005, 09:22 PM   #1
Hiddenlites
Hiddenlites is on a distinguished road
Hiddenlites's Avatar
1993 SC2
Default Need to replace camshaft bearing cap - New or used?
I am finally reassembling my SC2 engine and am ready to drop the camshafts back in. Today I was cleaning my bearing caps and discovered that the E1 cap had a gouge in it as a result of improper storage. The gouge is on the surface that goes over the cam journal so there is no question that I need to replace it.
I'm thinking that after going through all of the work to rebuild the engine, I shouldn't be installing used parts. It's not likely that the parts stores in the area will have a new replacement in stock, so that means I'll have to wait until next weekend before I can put my cams in.
On the other hand, if there is no harm using a used cap, I can pick up it from the junk yard tomorrow, and will be able to be close to finishing the engine reassembly tomorrow.
What are your thoughts on this?
1993 Saturn SC2 75k
2004 Chevy Silverado Z71
2008 Saturn VUE Redline 175k sold 7/8/16
2013 Honda Accord Coupe
2016 GMC Acadia
Hiddenlites is offline   Reply With Quote
Old 09-25-2005, 12:06 AM   #2
tabb
tabb is on a distinguished road
Default Re: Need to replace camshaft bearing cap - New or used?
The cam bearing caps are align bored. Meaning they are matched to the head. To get new, you must buy the entire head. I would not risk installing a used one. If It doesn't snap your camshaft in half during install, it'll drastically shorten the life of it.
If the gouge isn't too deep, you may be able to smooth it out with some crocus cloth and reuse it.
tabb is offline   Reply With Quote
Old 09-25-2005, 01:26 AM   #3
sc2dave
sc2dave is on a distinguished road
sc2dave's Avatar
have a machine shop align bore it.
sc2dave is offline   Reply With Quote
Old 09-25-2005, 04:13 PM   #4
Luke
Luke's Avatar
> Fm Dave <
> have a machine shop align bore it. <
That may have been a simply answer/suggestion for you. You know, with the level of tech experts and very familar auto techs on this site, I wonder if we should keep this site/forum a secret. Why ? Because most of the answers can well be applied to any car, in terms of general guidance and suggestions for problem analysis.
Don't mind me; I'm just wondering on. Understand my humor; for the feedback here, one cannot put a dollar value on it. How does one place a dollar figure on lengthy and personal expertise ??? Luke, get back on the truck........
Luke is offline   Reply With Quote
Old 09-26-2005, 12:16 AM   #5
sc2dave
sc2dave's Avatar
so, in other words?
camshaft cap bolts sr20fd3st S-Series Tech 4 02-05-2009 01:13 PM
over torqued bearing cap bolt? sc235k S-Series Tech 12 09-13-2006 11:07 AM
What is the most efficient cleaner to use for camshafts and camshaft bearing caps? Token S-Series Tech 2 01-29-2006 09:16 AM
Any Need to Replace Radiator/ Expansion Tank Cap? Leadsled Coupe S-Series Tech 2 09-08-2005 07:49 AM
Replace the gas cap when replacing CCPS GmG Miscellaneous Tech 3 12-03-2003 05:37 AM
