Old 11-14-2003, 09:22 AM   #1
OldGeezer
OldGeezer is on a distinguished road
Question 5spd automatic "shift flare" TSB question
I have a quick question for any Saturn tech people out there, as well as anyone who had the "shift flare" TSB performed. Does the tranny have to be completely pulled to do this? I may be wrong, but I thought I read here that someone was having it done and needed a loaner because it takes a couple of days. If that is the case, I have to wonder if it is worth all that. Mine does "rev up" and hard shift occasionally between the 2-3 upshift but if it needs to be pulled and take 2 days I may not bother.
OldGeezer is offline
Old 11-14-2003, 10:59 AM   #2
yellekkelurock
yellekkelurock is on a distinguished road
yellekkelurock's Avatar
2003 ION-3 Sedan
Default
There have been threads that have gone through about this.
1st thread
2nd thread
yellekkelurock is offline
Old 11-14-2003, 12:22 PM   #3
OldGeezer
Default TSB specifics
Thank you. I just checked those 2 threads. I am specifically asking about TSB # 03-07-30-052 in the thread started by "robh456" on 10-29-03. I am trying to find out what is involved mechanically with that TSB, whether or not you have to have the entire tranny pulled.
Old 11-14-2003, 09:41 PM   #4
KrgION03
KrgION03 is on a distinguished road
KrgION03's Avatar
Default Re: TSB specifics
I have the same question.
Kyle
18 Range Rover Velar R-Dynamic, Narvik Black
15 Porsche Cayman, Carrara White
Previous:
13 Porsche Boxster
09 Mercedes-Benz C300
06 Mini Cooper S
05 Saab 9-3
03 Saturn Ion2
KrgION03 is offline
Old 11-14-2003, 11:18 PM   #5
robh456
robh456 is on a distinguished road
Default
No, it does not appear that the transmission has to be removed to replace the valve body. The control valve body cover is on the front of the transmission (as seen when looking from the front of the car), after removing the transmission cooler lines, taking the cover off, disconnecting the shift solenoid connectors and removing the fluid temperature sensor, the valve body can be unbolted and removed.
robh456 is offline
Old 11-15-2003, 03:35 AM   #6
SpiderWebb
SpiderWebb is on a distinguished road
SpiderWebb's Avatar
Default
Does the shift flare only happen in 5 speed automatic Ions? I'm thinking about settling for 4, that is if my local dealer has the 4 speed Ion. I don't think I've gotten a definite answer to if the 4 speed is actually still available in 2004 models, but I think I do remember reading something about that... I can't remember. This is what happens when you post late at night.
SpiderWebb is offline
Old 11-15-2003, 05:13 AM   #7
robh456
Default
There is no 4-speed available on the Ion. It's either the 5-speed (on the sedan), the VTi continously variable transmission (on the Quad Coupe), or the 5-speed manual.
robh456 is offline
Old 11-15-2003, 06:36 AM   #8
SpiderWebb
SpiderWebb's Avatar
Default
I just remembered where I read about the 2004 4 speed Ion, and it was at my local dealers web site. I just went there, and this is the information that came up on the first 2004 Ion sedan I clicked on:
Mileage: New
Body style: 4DR SEDAN
Transmission: A4
Color: LIGHT SILVER
Could this be a typo?
Edit: They seem to have "A4" for all the automatics, but the manual I just looked at has "M5".
Old 11-15-2003, 08:50 PM   #9
robh456
Default
It is a typo - there's definitely no 4-speed auto available on the Ion. I would guess their system has no way to put a 5 in that field or something.
robh456 is offline
Old 11-15-2003, 11:10 PM   #10
Dan Pressly
Dan Pressly is on a distinguished road
Default
when they say 4 speed, maybe they mean 4 speed + overdrive.
Dan Pressly is offline
Old 11-16-2003, 04:13 PM   #11
WopOnTour
WopOnTour will become famous soon enough
WopOnTour's Avatar
Default
Geezer
While the valve body CAN be replaced without removing the transaxle, there are 2 different valve body part numbers depending on the transaxle assembly part number. So if you want to have the repairs done in the most efficient manner, call ahead and see if they have both valve bodies in stock.
You might even be able to scope out the AF23 part number your self. It's on a tag on the top of your transaxle and viewable (sort of) from under the hood.The tag is just behind your bell-housing where the transaxle bolts to the rear of the engine. The number on the RH side of the tag is the transmission part number (Technically the first 5 digits combined with the 3 directly underneath- but all that really matters is the last 3 numbers):
If your number is PN#24226418 or 24226999, then you need valve body assem PN#24228787. If your transaxle is PN#24224464 then you need valve assem PN#24226260.
They will need to reprogram your Transmission Control Module as well (after the repair)
All this assumes your complaint is: "Engine appears to be over-rev briefly (aka flare) during 2-3 upshifts at light - moderate throttle openings" and they can verify the concern.
HTH
Regards
WopOnTour
WopOnTour is offline
Plastic Torpedo's S-Series Automatic Transaxle "Reverse Slam Cure-All" Question sdasilva S-Series General 7 08-28-2016 05:34 PM
"Shift flare" questions... lauren Ion Tech 9 12-15-2009 01:41 AM
Shift Flare TSB question jeepinwi Ion Tech 15 12-07-2008 05:10 PM
is it possible to "shift kit" an automatic? sc2dave S-Series Mods 15 12-16-2006 04:39 AM
Had the transmission "flare" fixed... KI8GW Ion General 5 02-06-2004 04:16 PM
