Old 12-01-2019, 03:47 AM   #1
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Dizzy What PAG Oil do Ion's compresser use?
What PAG oil does the 2004 Sat Ion use and how much PAG oil should be installed after removing my old compressor which worked just fine.
This is just preventitive maintenance while I change my engine so NOT replacing my A/C compressor.
ddemier7 is offline   Reply With Quote
Old 12-01-2019, 01:42 PM   #2
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
Default Re: What PAG Oil do Ion's compresser use?
The system only needs 5 ounces of PAG 46 according to the service manual. How much you need to add depends on how much was lost when the compressor was removed. If none was lost then you shouldn't need to add any, but it probably wouldn't hurt to add an ounce.
2007 Ion 2 Quad Coupe 5-speed manual 183K miles
2007 Chevy Equinox LT 195K miles
2018 Chrysler Pacifica Touring L 48K miles
Old 12-02-2019, 12:28 AM   #3
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Thumbs Up Re: What PAG Oil do Ion's compresser use?
While I have my engine out I thought about changing my PAG oil since im swapping over my compressor. Would you recommend me changing my compressor oil because I have a pretty new bottle of PAG 46 oil.
Just thought I would do it because its extremely easy tonacess right now.
Old 12-02-2019, 10:15 AM   #4
ruley73
ruley73's Avatar
If you already have the oil, then I might do it. Otherwise, it's probably not necessary.
Old 12-03-2019, 01:23 AM   #5
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Thanks
A/c Compresser not starting? Davesnothereman Vue Tech 1 05-30-2016 11:31 PM
wts ecu,seats,& ac compresser....and motor parts for sohc turbosaturn4me Classifieds 11 08-13-2006 11:01 PM
