Old 11-12-2017, 05:46 PM   #1
moogoogypan
moogoogypan has a spectacular aura aboutmoogoogypan has a spectacular aura aboutmoogoogypan has a spectacular aura about
Default load rear wheel(?) noise
Got load wheel noise coming from rear drivers side on my 2005 standard, two wheel drive Vue. Had the wheel bearings replace a wile back. Thought it was flat spots on worn tires but replacing them did not cure problem. Ended up replacing the bearing again myself but that did nothing.
Noise increases with speed and is worst at around 50 MPH.
The threads seemed to all point toward bearing issues which i am almost sure is not the issue.
Stumped
cheers
moogoogypan is offline   Reply With Quote
Old 11-14-2017, 12:07 PM   #2
thegreatbriguy
thegreatbriguy has a spectacular aura aboutthegreatbriguy has a spectacular aura aboutthegreatbriguy has a spectacular aura about
2004 VUE 2.2L
Default Re: load rear wheel(?) noise
try the other side wheel bearing.
thegreatbriguy is offline   Reply With Quote
Old 11-14-2017, 12:12 PM   #3
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
^^ Yes Agreed! I've been fooled several times on which side was making the noise.
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Old 11-14-2017, 02:52 PM   #4
BobWolf
BobWolf will become famous soon enough
2006 VUE 2.2L
Did you re-torque the wheels after replacing the bearing? Check the wheels make sure they are snugged down right, check the lugs and nuts for rust, wear, and stretching. Also check spring rubbers, sway bar links, and shock bushings as well they can allow road noise to travel through when the bushings have wear. Don't cheap out on the bearings. I recommend MOOG or National. They're a little more pricey but will outlast the elcheapo brand parts.
We are all born ignorant, but one must work hard to remain stupid.
Benjamin Franklin.
BobWolf is offline   Reply With Quote
Old 11-14-2017, 02:59 PM   #5
BobWolf
2006 VUE 2.2L
Benjamin Franklin.
Old 11-14-2017, 04:03 PM   #6
SylenThunder
SylenThunder is on a distinguished road
SylenThunder's Avatar
2003 VUE 2.2L
2004 VUE 2.2L
Had a similar issue with my '04 recently. Just replaced both the rears. Shortly after fronts went too. Moog all around. Really cannot beat the little bit extra for premium parts.
2004 FWD, Vti, 2.2L
Custom CAI
SylenThunder is offline   Reply With Quote
Old 11-15-2017, 11:53 AM   #7
lord_varon
lord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of light
lord_varon's Avatar
2008 VUE 3.6L
Like the others have said, replace both wheel bearings again.... with quality parts... Vues seem to eat wheel bearings for lunch.... especially the cheap ones... If you have them making noise, put in good quality replacements....
John
aka
Lord_Varon
07 Vue V6 AWD LOADED!!! aka SUPER CRITTER!!! Sadly gone, and definitely missed.
08 Equinox Sport 3.6 6 spd auto, AWD, even more loaded. And the jury is still out on it.
lord_varon is offline   Reply With Quote
Old 11-15-2017, 09:53 PM   #8
moogoogypan
Thank you gentlemen,
Did not torque the bolts holding the bearing but cinched them down well.
Thinking maybe some other issue like the "spring rubbers" mentioned.
The sound is a repetitive thud noise that speeds up with increased speed almost like a wheel out of round. At the same time there is no perceptible vibration. Some suspension issue seems a good possibility.
Not sure how to go about such a test.
Noise from rear wheel. Wheel bearings going? Rochester S-Series General 7 05-23-2017 12:49 AM
Vue rear wheel noise,help. Midnight13 Vue Tech 14 07-10-2013 09:36 PM
2004 FWD Vue Rear Wheel Noise genistas Vue Tech 4 01-25-2011 10:11 PM
Rear wheel noise DcRedz L-Series General 3 10-05-2005 10:50 AM
Clicking noise from the rear wheel BlackOnyx Vue General 14 06-16-2004 11:37 AM
