Old 09-29-2014, 09:10 AM   #1
buduranus2
buduranus2 is on a distinguished road
1999 SW2
Default Odd "sliding" noise in/under dash when first accelerating 1999 SW2
My 1999 SW2 makes an unusual noise ONLY when first accelerating after starting it. The sound is like a pocket tire gauge sliding front to back in the center console, which it isn't. It only occurs once after starting. That is to say, it DOES NOT occur when accelerating from a stop after the first time. Really perplexing. Seems like it's coming from within or under the dash. No difference if AC is on or off. Any thoughts or insights?
buduranus2 is offline   Reply With Quote
Old 09-29-2014, 01:02 PM   #2
Default Re: Odd "sliding" noise in/under dash when first accelerating 1999 SW2
Pull the ABS fuse out, you won't have that noise anymore. You won't have ABS either and the light will be on, but you wont have the noise of it activating.
Old 09-29-2014, 01:16 PM   #3
^^^^^ Or just read the section in the owner's manual about ABS, and you'll realize that it's perfectly normal. It might be advisable to post again if you DON'T hear it sometime in the future.
Old 09-29-2014, 02:26 PM   #4
buduranus2
1999 SW2
Thanks for your reply. So now I've got a decision to make: ABS or noise? Hmmm, really need to think about this one. Thanks again!
Old 09-29-2014, 02:37 PM   #5
buduranus2
1999 SW2
Thank you also. I guess I never noticed this in my 1997 SW2 (211,000 and counting) because it doesn't have ABS.
Noise from dash "buzzing" blaisedaddy Ion Tech 12 12-11-2017 02:32 AM
1999 SL2 tranny issue Girl worries garage is not "kosher" alseISme S-Series Tech 8 04-27-2012 10:02 PM
Pass side A pillar / dash "creak" noise golftango Aura General 9 11-15-2010 03:33 PM
1999 sl1 (standard) code P0341 "front pipe leaking" lrk S-Series Tech 3 03-30-2009 01:14 PM
1999-SL2 Power Window Regulator "Repair?" kgilb11771 S-Series Tech 4 01-16-2008 08:28 PM
