Old 03-10-2003, 08:52 PM   #1
VTHokie00SL2
VTHokie00SL2 will become famous soon enoughVTHokie00SL2 will become famous soon enough
VTHokie00SL2's Avatar
Question Failing alternator?
Tonight as I was driving home, my lights started to dim on me. Then, as they returned to normal brightness, there was a brief squealing sound, almost like what a loose serpentine belt sounds like. Does the alternator seem like the most likely suspect? It is the original, and at 146,000 miles it's probably well past due.
VTHokie00SL2 is offline
Old 03-10-2003, 09:30 PM   #2
dancingator
dancingator is on a distinguished road
Default
The 1997+ cars have good alternators. But 146k miles is a lot of driving - though probably a lot of highway????
You can get most auto parts stores (autozone, discount auto) to check the alternator for free. You may also want pop your hood and check out your belt and tensioner, regardless.
Sometimes I think my lights dim on me. But it never turns out to be anything.
dancingator is offline
Old 03-10-2003, 09:50 PM   #3
cormor
cormor is on a distinguished road
cormor's Avatar
1997 SL1
Default
I had to get a new alternator for my 97 sl1 around 50k miles. With this new high tech battery i have no problems using my headlights and have my subs going.
cormor is offline
Old 03-10-2003, 10:35 PM   #4
Default
Could be the alt? The squeal noise makes me think that you should check the belt and or tensioner as well. If the tensioner is gone then the belt will not have enough grab to run the alt.
ssicarman is offline
Old 03-10-2003, 11:01 PM   #5
therapist
therapist is on a distinguished road
Default
vthokie, usually the idiot battery light will light up when the alt goes. however the 1st indicator usually is a rough shifting auto transmission.
therapist is offline
Old 03-10-2003, 11:24 PM   #6
VTHokie00SL2
Default
Thanks for the feedback!
I agree...definitely a possibility.
Old 03-11-2003, 12:22 AM   #7
94sc293sl1
94sc293sl1 is on a distinguished road
94sc293sl1's Avatar
1994 SC2
Default
Does your car have ABS? Shortly (i.e. hours) before the alternator went out last year on my SC2 the 'anti-lock' light came on and stayed on.
Craig
Saturn owner no longer as of 12/21/05, sold my SC2.
www.insidetrackmagazine.com
94sc293sl1 is offline
Old 03-11-2003, 01:14 AM   #8
VTHokie00SL2
Default
Yep, I have ABS. Wow, hours, huh? Like how many hours? :o:
Question: how long can you last on the battery once it stops charging?
Old 03-11-2003, 01:29 AM   #9
94sc293sl1
94sc293sl1's Avatar
1994 SC2
Default
Not many hours at all. I noticed the anti-lock light in late afternoon when I went to the store, then returned home. Later I was on the way to a meeting. Light was on when I started. Less than 10 minutes later light still on, wipers slowed, overall lights dimmed, then the alternator died.
Craig
Old 03-11-2003, 01:56 AM   #10
Qlara
Qlara's Avatar
Default
I was one time driving over 30 miles in my Alt-failing SL2.
Thank god my battery can last the whole trip (60% highway only), and I did use A LOT of (power management) techniques like press less Brake pedal (Tail lights drains a lot!). No fan, No AC and of course No Radio, just to give all the battery power to the motor.
I can verify the Anti-Lock lights up....in my mid-way trip. I thought the ABS started failing too, but not really.
When the Alt gone, the Battery Red does light up.
Qlara is offline
Old 03-11-2003, 10:38 AM   #11
eRic 02sc2
eRic 02sc2's Avatar
Default Re: Failing alternator?
wow. 146,000 is excellent. mine only lasted about 60,000 each time. get it checked out.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 03-11-2003, 01:29 PM   #12
piney
piney will become famous soon enoughpiney will become famous soon enough
piney's Avatar
Default
While it is rather embarassing to have one's car there, Manny Moe & Jack did the new alternator for me with a lifetime parts warranty for just over 200 bucks on the 1997.
piney is offline
Old 03-11-2003, 01:42 PM   #13
eRic 02sc2
eRic 02sc2's Avatar
Default
200 bucks. ouch. i recall paying less than that at saturn. it was like $100 for the part and 45 min of labor.
eRic 02sc2
Old 03-11-2003, 02:48 PM   #14
dieseljack
dieseljack is on a distinguished road
Default
Saturn's $125.00 price for a reman exchange alternator seems to have been reasonable. They also have been offering a one year warranty if you install it, and a three year warranty if the dealer does. I have a feeling that the remans they provide are actually brand new units, thus controlling the exchanged cores and keeping them out of the independent rebuild shops. Yet, there has always been a very stearn pronouncement in the various division shop manuals over the last fifteen years that the CS130 alternator was to be serviced as a assembly, and not rebuilt. This opens up the floodgates for the various aftermaket venues to provide "off the shelf" units that may or may not be suitible for a specific model year, especially OBD II vehicles against earlier models.
Mine is still cookin' at 290 K, but I know that some day it'll call it quits, and I'd hate to throw the whole thing away. In contrast, both the alternator and starter on my RSX can be repaired using over-the-counter items such as brushes, rectifier, and voltage regulator. Stator, rotor, armature, and field coils could last forever. This, I think, is the best way to go, and certainly the cheapest.
dieseljack is offline
Old 03-11-2003, 03:32 PM   #15
1993 Blue SL2
1993 Blue SL2 is on a distinguished road
Happy
I was a master at making my car last when the alternator started dying! In a period of 20,000 miles on my 93 SL2 I had 3 alternators on it. Once my alternator finally decided to die in Charleston SC, and I drove all the way back home to Spartanburg, SC which is approx 300 miles. I just put all the windows down, turned the radio off, and minimized the load as much as possible. The whole way the speedometer was bouncing all around and not keeping a constant speed. Needless to say by the time I made it back home the car was DEAD...the passive restraints were barely moving! My 98 SL2 is good so far, no alternator problems and over 100K! (knock on wood)
1993 Blue SL2 is offline
Old 03-11-2003, 04:38 PM   #16
RicSC2
RicSC2 is on a distinguished road
2000 SL2
Default Alternator
The alt on my 95 sc2 (auto), went at 60k. First the alt light came on. I drove to an Autozone and they confirmed that the alt was bad. The next day on the way home from work (50 mile round trip) the alt died. The transmission was stuck in third gear, the speedo stopped working...made it home though. I didn't realize it would go that quickly. I put a new lifetime alt on and everything is fine now.
RicSC2 is offline
Failing alternator? sps SOHC S-Series Tech 72 07-14-2008 11:18 PM
Failing clutch? hit_n_run S-Series General 2 03-04-2008 08:22 AM
Battery light turns on 30 seconds after starting car, failing alternator? phitchow L-Series General 4 08-14-2006 03:59 PM
Failing alternator? sps SOHC S-Series Tech 6 04-22-2005 10:32 AM
alternator failing??? sps SOHC Miscellaneous Tech 2 11-01-2004 12:40 PM
