Old 08-09-2009, 05:22 PM   #1
schwghrt
schwghrt is on a distinguished road
Default '96 Sl2 Manual Trans Rebuild questions
Hi all,
Just pulled the engine out of my 96 Sl2. I was having troubles shifting into first and second. Replaced all the clutch components, but I feel like I should re-build the transmission while I have the engine out. (I'm not sure if the clutch, or the transmission was at fault.) Is there a good manual on how to do it? My Haynes, just says don't even try.
Thanks.
schwghrt is offline   Reply With Quote
Old 08-09-2009, 06:48 PM   #2
rc1488
rc1488's Avatar
Default Re: '96 Sl2 Manual Trans Rebuild questions
differentracing.com under tech articles shows you how to take it apart. Use the search button to find where to get a rebuild kit. I forget where.
Most times hard shifting into 1st is due to worn pressure plate fingers, not internal issues with the tranny. These trannys are beasts
Old 08-09-2009, 06:56 PM   #3
1995sl1sohc
1995sl1sohc is on a distinguished road
1993 SL1
Weld the diff pin! It took me about an hour to disassemble the trans and about an hour to reassemble. I don't have it in the car yet, but I am pumped to get this thing going!
1995sl1sohc is offline   Reply With Quote
Old 08-09-2009, 09:03 PM   #4
schwghrt
Yeah, the pressure plate fingers were definitely worn, but it didn't feel like the clutch was dragging. Could that still be the problem?
I took off the 5th/reverse cover, and it looks pretty good. I'll probably pull the main cover off just to check. Only the cost of a few gaskets. (Assuming that I don't mess anything up.)
Old 08-09-2009, 09:24 PM   #5
1995sl1sohc
1993 SL1
If you are going to take off the main case, you are 2 bolts away from popping the differential out! After you remove the main case remove the brass flow tube, then remove the 2 bolts holding the reverse bracket deal, remove the bracket. Next remove the reverse idler gear and shaft. Next Grab the input shaft, output shaft, and selector fork and remove them from the case as an assembly. Then grab ahold of the differential bearing and pull up. Have the pin welded in and put it back together!
http://www.differentracing.com/tech_...sassembly.html
These guys have an excellent write up with pictures and everything.
The diff pin is the weakest link on these trannies, so have it TIG welded if you are opening it that far. Careful not to heat it to much when welding as there are plastic washers behind the gears that will melt.
Old 08-09-2009, 10:17 PM   #6
schwghrt
What size is the nut on the input and output shafts. It's slightly larger than a 29mm.
Thanks
Tags
manual sl2 1996
94 SL2----Manual Trans questions 2NDSOUT S-Series Tech 2 05-01-2008 07:46 PM
1993 SL2 manual trans questions juspay4speed S-Series Tech 1 12-09-2007 09:52 PM
Manual Trans questions 2NDSOUT S-Series Tech 8 09-11-2007 01:03 PM
Manual Trans rebuild? jeffmeden S-Series Tech 0 06-22-2006 10:50 AM
Auto trans to manual questions Da_Rockwilder12 S-Series Tech 0 03-11-2005 05:21 PM
