Old 06-03-2009, 12:09 AM   #1
soontobespeed
soontobespeed is on a distinguished road
Default whining noise
car is experiencing whining noise when it runs. i think its the waterpump but brother thinks its power steering pump. anyone got an idea?
soontobespeed is offline   Reply With Quote
Old 06-03-2009, 01:53 AM   #2
ahimsa1
ahimsa1 is on a distinguished road
1997 SW1
Default Re: whining noise
I would use a mechanic's stethoscope to listen to the parts you suspect to see which one is generating the noise. If it's inconvenient to get one, you can try putting a pipe or long screwdriver on the part, and carefully putting your ear on that to listen.
97 SW1 Auto 174k
ahimsa1 is offline   Reply With Quote
Old 06-03-2009, 09:09 AM   #3
DonP
The alternator also can make a whining noise, and is the more common source in my somewhat limited experience. The bad water pumps I've experience tended to leak at the shaft or make a "clatter" noise rather than whine, and similarly the power steering pumps have tended to leak a bit at the shaft as they were going bad. But your case may be different.
Listen to localize as suggested above.
And welcome, check your ECTS per many other threads, and perhaps add you year and model to your profile - it helps others when you ask questions because some issues tend to be year/model specific
Old 06-13-2009, 03:49 PM   #4
ahum80
ahum80 is on a distinguished road
Thumbs Up Re: whining noise
I too had a whining noise. Was like that for over a year until one day my idler pulley locked up and threw the belt. I replaced the idler pulley and belt. It fixed it completely. Now it is quiet as can be.
ahum80 is offline   Reply With Quote
Old 06-13-2009, 04:32 PM   #5
IMkenNY
IMkenNY is on a distinguished road
I had a terrible whining noise last year, it went away after my mothernlaw got out of the car.
IMkenNY is offline   Reply With Quote
Old 06-13-2009, 08:12 PM   #6
red92xblue
red92xblue is on a distinguished road
red92xblue's Avatar
Make sure you check the transmission fluid level(automatic). A low level will create a serious whine sound!
red92xblue is offline   Reply With Quote
whining noise (03 Vue) isenor Vue General 6 09-27-2008 12:58 PM
Whining noise JohnnyRotten L-Series General 2 09-24-2006 12:45 AM
Whining noise Smokey S-Series Tech 19 06-29-2006 08:01 PM
whining noise swoker183 S-Series Tech 17 02-11-2003 02:07 PM
Whining Noise wrightco S-Series Tech 4 07-25-2002 09:40 PM
