Old 10-27-2008, 09:02 AM   #1
David Grigor
David Grigor is on a distinguished road
1995 SW2
Default 95 SW2: Help with Code 19
Thanks to this forum I had grown pretty confident with working on my 2002 SL2 that I decided to buy a cheap fixer upper 1995 SW2 auto w/ 140K, engine seems to run fine but SES light on.
Immediately upon getting the car I did the following, new fuel filter, plugs, wires, air filter, etcs, thermostat, oil&filter change, ATF change w/filter, valve cover gasket ( oil all over the top and in the spark plug wells ).
It seems to run good, many more rattles than my 2002 but then again the car is 7 years older too.
Anyways, SES still one. Did the paper clip and get code 19.
Did searches on here and points to CPS but most of the posts mention the car doesn't run. Seems to run fine no obvious misses. I went ahead and replaced the CPS anyways. Did not fix it.
Symptoms: It may or may not be related but the RPMs guage reads low and is sporatic and bounces around. About the first 30-45 seconds of starting the car the SES light will be off and the RPM guage doesn't move. Right when the SES light comes on the RPM guage starts to move but for sure reads low and bounces not steady. The idle of the car seems pretty normal for a cold start. No issues starting.
Any advice where next to start ? Not for sure where the other end of the CPS wires lead to for checking.......
David Grigor is offline   Reply With Quote
Old 10-29-2008, 05:52 AM   #2
BarnOwl
BarnOwl's Avatar
Default Re: 95 SW2: Help with Code 19
I'm sort of shocked to hear of an S-series getting that code. I'd replace the sensor but, it's probably the wiring. I don't have the wiring for a '95.
Old 10-29-2008, 10:47 AM   #3
Go here, its a 6x signal failure. Could be a connector or bad wire but its not the CPS failure. Its the ICM module.
http://www.saturnwiki.net/index.php/...X_Signal_Fault
Old 11-01-2008, 06:47 PM   #4
David Grigor
1995 SW2
Thanks guys. What a great help.
Got a ignition control module from the pick and pull for $16 and back in business...... the RPM guage is reading more normal and the SES gone.
99 SW2 PO303 code kufman S-Series Tech 13 12-13-2009 09:43 PM
97 SW2 code p0134 GQROD S-Series Tech 18 06-27-2009 01:01 PM
00 SW2 Radio Unlock Code Sailor Tom S-Series Tech 8 04-21-2008 12:45 PM
00 SW2 Radio Code Sailor Tom S-Series Tech 1 02-09-2007 07:52 PM
98 SW2 Engine Code Urbanrover S-Series Tech 1 04-05-2005 11:55 PM
