Old 09-23-2008, 03:52 AM   #1
CND_SC1
CND_SC1 is on a distinguished road
CND_SC1's Avatar
1994 SC1
Default Body Question: Replacing front upper bumper cover
I guess this isn't fixable by any combination of heating, pressing & rolling it back into it's original shape?
CND_SC1 is offline   Reply With Quote
Old 09-23-2008, 04:05 AM   #2
CND_SC1
CND_SC1's Avatar
1994 SC1
Default Re: Body Question: Replacing front upper bumper cover
The line you see in the recess in front of the headlight is not just a shadow but also a fold in the plastic. (Some sort of styrofoam like stuffing that's apparently tucked between the plastic and the bumper was also disturbed )
I read somewhere that when installing S-Series body panells, the bolts must be fastened in an exact sequence with each one torqued to specific tension to allow the polymer panells to "move" as they expand & contract.
Does this also apply to the front bumper cover, or can any amateur line it up and bolt it on?
Is there any chance that I and a helper with absolutely no experience (other than re-installing side mirrors & rear headlight lenses) could replace this properly by going slowly and logging each step during disassembly?
If not, are there any special instructios I can find online and pass on to a cheapo body guy so I can avoid a dealership body shop part & labor costs?
Old 09-23-2008, 12:25 PM   #3
The bumper cover is held on with push pins, which allow expansion and t3 or 4 screws from the fender. Take the cover off and see what else is bent up. Lay the cover out in the sun straight and the ripple will come out of it.
Body panel info is down at the bottom
http://www.differentracing.com/tech_articles/index.html
There are also the richpin videos. At the bottom of the page take the Forum Jump to the How-To Library and the video links and index is one of the top 3 posts. Detailed instructions on how it get it all apart.
Old 09-23-2008, 10:59 PM   #4
off-track
off-track's Avatar
Being in the frozen north it might need a little coaxing with a hair dryer or (careful) application of a heat gun on the back side.
Low speed parking lot "altercation"?
Very easy to remove the fascia. I haven't done it but.. if the foam is buckled up higher than normal you probably can smooth it down with a box rasp?
Purchased 114k 10/07
Added OEM CC
Old 09-23-2008, 11:31 PM   #5
Once i had a look at the hidden damage I would probably just get a tube of that urethane caulk they are selling now or the latest construction adhesive and glue the foam back together and then rasp to fit. Bright sun should warm it up enough even on a fall day. If not then the hair dryer will do it. You want it too hot to touch if you are applying heat and then gently press it back and hold it till it cools. Need oven mitts.
For Sale: Front end bumper cover, Hood cover, and Dash cover firevswater5 Classifieds 2 08-04-2006 11:24 PM
WTB: 94 SL2 Upper Front Bumper Cover and Rear Passenger Door Glass chugg Classifieds 4 02-04-2006 06:53 PM
WTB: 1st gen upper front bumper or whole bumper s-seriesguy Classifieds 0 12-11-2005 03:15 PM
Replacing rear bumper cover mhzjnky Vue General 5 11-17-2004 01:50 PM
WTB: Upper/Lower bumper cover from 95-96 SC2 QwikSC2 Classifieds 0 04-20-2004 01:42 PM
