Old 07-13-2008, 08:47 PM   #1
Forrest
Forrest is on a distinguished road
2007 VUE 2.2L
Dizzy What type transmission fluid?
I would really like to replace the fluid in my tranny with a synthetic.
It's a 2007 with the 2.2 and a manuel 5-speed. The owners manual specs say to use GM Part No.88861800. Does anybody know what aftermarket synthetic would be the equivalent?
I can find listing for the older VUE's, but nothing for the 2007.
Forrest is offline   Reply With Quote
Old 07-16-2008, 09:16 PM   #2
original007
original007 is on a distinguished road
Default Re: What type transmission fluid?
not to tell you what to do but a manual trans put little stress on the fluid, low heat just kind of splashes around and lubes some bearings factory stuff is really all you need. Synthetic is just a feel good thing in this case.
original007 is offline   Reply With Quote
Old 07-17-2008, 07:02 AM   #3
Ritz
Ritz's Avatar
Nonsense. It makes a noticeable difference in the shifting smoothness, especially if you live in a cold climate. It will also resist breakdown for much longer than conventional fluid.
Cheers,
Old 07-17-2008, 07:09 AM   #4
Ritz
Ritz's Avatar
To the original poster:
I believe a few posters here were using Redline synthetic with good results. Do a quick search on the tech forums. GM #88861800 is simply DexronIII transmission fluid. So that would be Redline part D4 ATF. Mobil1 synthetic ATF is also suitable.
Cheers,
Old 07-17-2008, 05:01 PM   #5
David 93 SL2m
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Happy Re: What type transmission fluid?
The back of the owner's manual will have the type of transmission fluid required. For a 2007 VUE with a manual transmission you might need an ATF that meets (or exceeds) DEXRON-VI specifications, such as this synthetic blend from Mobil:
http://www.mobiloil.com/USA-English/...on_VI_ATF.aspx
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
David 93 SL2m is offline   Reply With Quote
ATF Fluid Type 97sl2DOHCaut1.9 S-Series Tech 8 12-28-2009 06:24 PM
S-Series Trans Fluid type??? dlacacres S-Series Tech 7 10-31-2009 12:15 PM
5spd Transmission Fluid Change - Fluid? Satsational S-Series Tech 17 10-20-2008 06:57 AM
Type of tranny fluid for 97 SL2 Pioneer_Saturn S-Series General 5 04-03-2008 12:24 AM
2000 SL1 Transmission Type? Frank3 S-Series Tech 2 12-31-2005 10:02 AM
