Old 05-23-2008, 07:09 PM   #1
hschofield
hschofield is on a distinguished road
Default '96 Won't Start After Rebuild
I did an in-frame rebuild on a '96 DOHC. Car started up fine over three weeks ago. I've been driving it every two or three days over the last few weeks to break everything in. Drove it today, no problems. Got home and parked it in the garage and now it won't start. Below are the issues:
It turns over but will not start. Was able to restart it once with starting fluid.
After searching the forum for the last 3 hours I have narrowed it down to possible the CPS. I did the test just like Richpin's video by pulling the plugs of the coils...however, I get sparks between the two posts on both coils.
The fuel pump runs and primes as normal. Checked the fuel pressure and it was fine.
The tachometer does not move when ing. Points to CPS issue?
Can the CPS be faulty even though I get sparks? Don't want to be changing out perfectly good parts.
Thanks for everyone's help.
hschofield is offline   Reply With Quote
Old 05-23-2008, 07:23 PM   #2
original007
original007 is on a distinguished road
Default Re: '96 Won't Start After Rebuild
If there is spark the cps is ok.Check fuses? Look near the #4 injector wire it angles towards the cam cover and can easily get pinched during assembly eventually shorting and blowing the injector fuse
original007 is offline   Reply With Quote
Old 05-23-2008, 08:43 PM   #3
hschofield
Thanks for the suggestion. Tested the fuses, they all look good. Listened to the injectors through a stethescope while the engine was being ed and they sound like they are working.
I'm really stumped on this one.
Old 05-23-2008, 08:47 PM   #4
Crank it over for a while and then pull a plug. Is it wet? If you have gas and spark it will run, maybe poorly but it will run.
Old 05-29-2008, 10:41 AM   #5
hschofield
I see there have been a couple of posts similar to mine. I have an update on my issue. Still won't start unless I spray some starter fluid in the air intake, then it fires right up. Do you think it could be the air intake sensor?
Any suggestions?
Old 05-29-2008, 11:48 AM   #6
Does it continue to run after starting on the starting fluid, or does it just burn up the starting fluid and stall?
Old 05-29-2008, 12:29 PM   #7
hschofield
It continues to run fine.
I drove it around for 20 minutes but when i returned home and shut it off it wouldn't start. Then I sprayed some more starting fluid in the air intake (where the air intake tube clips down onto the filter) and voila, she will start right up and run until I shut it off.
Did this 3 or 4 times to make sure it wasn't a fluke.
This isn't a cool vs hot engine issue either. It won't start when cool or hot unless I spray the starting fluid in the air hose.
Oh, one other thing. It does idle fast, about 2000 RPMs and the transmission will not shift correctly either. It won't shift unless I get over 3500 RPMs which means I have to get about 60 MPH for it to go into 4th.
Old 05-29-2008, 06:06 PM   #8
OldNuc, a new member with evidently a lot of experience, posted this: http://www.saturnfans.com/forums/sho...3&postcount=16 in another thread. _Might_ have some relevance to your issue....
Old 06-26-2008, 11:41 AM   #9
hschofield
Just thought I would give an update on my issue.
In tinkering with things I unplugged the wire to the TPS and the car would start and idle fine. So I replaced the TPS. It fires right up and idles perfectly now and the SES light that I had on went off also.
Old 07-15-2008, 12:42 PM   #10
hschofield
Another update. After a while the SES light came back on. Still P0304. I decided to check the injectors. Switched # 4 with # 3 and sure enough the code switche to a P0303.
Bought new injectors and she purrs like a kitten and no SES light for a few days now.
Thanks Everyone.
I start the rebuild of my 01' SL2 soon... TheOneJordan S-Series Tech 9 07-26-2009 12:13 PM
first start on rebuild head gkainz S-Series Tech 7 08-29-2008 11:24 PM
1993 sl2 no start after rebuild 1991sl1 S-Series General 2 02-04-2008 04:15 PM
95 SL2 - To Rebuild or not to Rebuild iss407 S-Series Tech 4 09-01-2006 05:58 PM
Seeking advice on engine rebuild (Subaru.. and rebuild done) Scyan Miscellaneous Tech 8 06-13-2003 09:38 AM
