Old 12-04-2007, 01:50 AM   #1
badtzbuzz
badtzbuzz is on a distinguished road
Default Looking for a Shorter Antenna
I have the problem with the Antenna hitting the garage door. Does anyone know of a shorter antenna whip that won't affect reception?
badtzbuzz is offline   Reply With Quote
Old 12-04-2007, 04:28 AM   #2
bigfatdave
bigfatdave is on a distinguished road
bigfatdave's Avatar
2006 ION-2 Quad Coupe
2001 SL2
Default Re: Looking for a Shorter Antenna
Yours is probably a different base than my ION or SL2 ... but why not go out and grab a stubby? They're pretty cheap and come with a handful of adaptors.
I replaced both cars' antennas with rubberized stubbies just because I think the whips looked silly. I noticed no measurable change in FM, and a bit of improvement in AM, which I was surprised by.
Hit up NAPA/Autozone/Advance and check out what they offer, if you're really cheap like me, pul your existing antenna and take it in to match with the connectors on the replacements.
still rolling
bigfatdave is offline   Reply With Quote
Old 12-04-2007, 04:51 AM   #3
scotted73
scotted73 is on a distinguished road
scotted73's Avatar
2007 Outlook XR
2002 L-Series 3.0L Wagon
At only 8" long with a 1" base, the antenna angles back and sits 8" high. It pretty much is a "stubby" antenna.
Maybe the antenna used in the Aura could work. Other than that, I don't have any options.
2007 Outlook XR AWD Charcoal
Ebony Leather, Captain's Chairs and everything else from the audio/video/convenience world
scotted73 is offline   Reply With Quote
Old 12-04-2007, 07:27 PM   #4
djhhjd
djhhjd is on a distinguished road
djhhjd's Avatar
2009 Outlook XR
Try adjusting your garage door opener so it lifts the door to the max amount. My garage door is a 16'x7' by and it clears by 4 or 5 inches easy. As a matter of fact I used to drive a 4x4 Ford EXCURSION in and out no problem.
djhhjd is offline   Reply With Quote
Old 12-04-2007, 11:21 PM   #5
badtzbuzz
No can do. It's already adjusted to the max. I think the previous home owner re-paved the garage floor and drive leading to it and had increased the slab thickness or re-directed pitch....DOH!
Old 12-05-2007, 12:22 AM   #6
eRic 02sc2
eRic 02sc2's Avatar
I got a Metra 44-RM1R rubber antenna for $5
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 12-09-2007, 10:03 PM   #7
monte70z20
monte70z20 is on a distinguished road
Not sure if it would work or if it is even compatable but what about one of the little stubbies that come on some of the Pontiac Montana's or Chevy Venture vans. They are pretty short and if they are compatible it would probably do the trick.
monte70z20 is offline   Reply With Quote
Shorter shocks necessary if I lower my car with springs? internetjunkee Astra Tech 13 09-21-2009 02:26 AM
how can i make the parking brake cable shorter? KawaiiBoricua S-Series Tech 8 08-01-2008 12:16 AM
Aura OK for shorter people? gordonwd Aura General 15 11-01-2007 09:23 PM
Is Shorter really better? kaviation Ion Mods 11 02-11-2007 05:13 PM
tricking ects into shorter warm up time? sc2dave Miscellaneous Tech 2 09-11-2004 12:13 AM
