Old 11-06-2007, 08:00 PM   #1
turbobuick33
turbobuick33 is on a distinguished road
turbobuick33's Avatar
1992 SL2
Default Whats trans fluid does everyone use in their manual trans?
What trans fluid does everyone use in their manual trans? Do you use Royal Purple? Mobil? Redline? or AMS?
92 SL2, 5 speed
91 Lx 5.0
turbobuick33 is offline   Reply With Quote
Old 11-06-2007, 09:36 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: Whats trans fluid does everyone use in their manual trans?
Mobil 1 ATF. Only b/c it's available locally.
Old 11-06-2007, 09:41 PM   #3
eRic 02sc2
eRic 02sc2's Avatar
Valvoline Dexron III compatible ATF.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 11-06-2007, 11:52 PM   #4
96GSL1
96GSL1 is on a distinguished road
96GSL1's Avatar
1996 SL1
Advance Auto Dex 3 Will switch back to Mobil 1 or a better Dex/Mercon fluid though; my cold shifting is not what it was.
96 SL1 202k
98 Windstar 123k
96GSL1 is offline   Reply With Quote
Old 11-06-2007, 11:57 PM   #5
tarsun
tarsun is on a distinguished road
motor oil..
or i did
now i dont know
havent had to add any in a while
tarsun is offline   Reply With Quote
Old 11-07-2007, 12:15 AM   #6
GmG
GmG is on a distinguished road
GmG's Avatar
1992 SC
Mobil 1 ATF, for no reason other than that a lot of people suggested it. Supposedly the tranny shifts smoother, but I've never actually been able to do a comparison.
George
92 SCm 138k
98 SC2m 131k
"You shouldn't leave things in the fridge. That is the lesson."
GmG is offline   Reply With Quote
Old 11-07-2007, 02:08 AM   #7
tiptop
tiptop is on a distinguished road
ya just any dextron/mercon 111
tiptop is offline   Reply With Quote
Old 11-07-2007, 02:10 AM   #8
Originally Posted by tarsun View Post
motor oil..
or i did
now i dont know
You _did_ change it, right?
Old 11-07-2007, 08:52 AM   #9
dmc
dmc is on a distinguished road
2000 SL2
I use Mobil 1 ATF, it makes cold shifts much easier.
dmc is offline   Reply With Quote
Old 11-07-2007, 10:34 AM   #10
supernad
supernad is on a distinguished road
supernad's Avatar
none
standard trans
supernad is offline   Reply With Quote
Old 11-07-2007, 11:17 AM   #11
MiSaturn
MiSaturn is on a distinguished road
2002 SL
1993 SL2
Mobil 1, which for some reason has gotten much more expensive. Will be looking for an alternative.
MiSaturn is offline   Reply With Quote
Old 11-07-2007, 12:14 PM   #12
AJT_Leo
AJT_Leo is on a distinguished road
AJT_Leo's Avatar
Why does it matter if the cost increases? You have already flushed and filled with m1. How often do you replace it?
The bureaucracy is expanding to meet the needs of the expanding bureaucracy.
AJT_Leo is offline   Reply With Quote
Old 11-07-2007, 01:48 PM   #13
Originally Posted by supernad View Post
none
standard trans
You better still have tranny fluid in it.
Old 11-07-2007, 02:00 PM   #14
Tercero
Tercero is on a distinguished road
Tercero's Avatar
1997 SL1
When should the fluid be changed, and should it be flushed? I was told last winter *not* to flush a transmission as it disturbs the filings that might end up where you don't them. Better to just drain your transmission and re-fill it.
Tercero is offline   Reply With Quote
Old 11-07-2007, 02:11 PM   #15
Well, this thread is about manual trannies, and the above statement refers to automatics, but it's still true.
Automatic trannies should be drained and refilled (with a new filter) every 30,000 miles, according to the owner's manual. Many here do it considerably more often, like every 6-10k. I'd consider 30k a bare minimum.
The manual tranny is supposed to be drained and refilled once, at 6,000 miles. Technically, from then on, it never needs it; remember, it's just a slosh/bath oil; no pressure, no hydraulics. But for good "hygiene", the general consensus here is that replacing it every 100,000 miles is a good idea.
Manual Trans Fluid sea2seajt S-Series Tech 7 12-24-2009 12:24 AM
Changing Fluid in Manual Trans. Maritime Storm Ion Tech 22 08-03-2007 03:42 PM
Checking fluid 96 sl manual trans wesjones S-Series Tech 7 08-06-2006 12:11 PM
manual trans fluid leak GmG S-Series Tech 2 07-20-2006 03:39 AM
Manual Trans Fluid dano92 Miscellaneous Tech 12 01-07-2002 11:42 PM
