Old 10-02-2006, 10:25 PM   #1
mekivokao
mekivokao is on a distinguished road
Default Saturn Shifter help!
Hi fellow Saturn owners. I am new to this site and group. i have a problem with my 96 SC2. just recently my shifter went loose. the "swivel joint, ball joint, bushing, or the plastic thing" that holds the shifter to the clutch rod/cable broke. i cannot switch because my stick is not connected to the cable. i did some research and apparently it is pretty common. i went to the saturn parts site and could not find anything related to the problem i have. i did though find out that saturn does not sell the specific part i need, but the entire assembly which who knows what is included. i was wondering if any one could direct me in any which way possible, or at least give me the correct part name. Thank you and any help is greatly appreciated.
- mekivokao -
mekivokao is offline   Reply With Quote
Old 10-03-2006, 03:11 AM   #2
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default Re: Saturn Shifter help!
unfortunately, you have to replace it all...the cables don't break, but the plastic retainer/grommet on the back does...and it's all one unit.
what'd they ask for it all? 300? 400? I'd honestly would just get a set from the junkyard if you have time.
M.Nguyen is offline   Reply With Quote
Old 10-03-2006, 03:24 AM   #3
xupthree60
xupthree60 is on a distinguished road
xupthree60's Avatar
when it cools down a few hundred degrees i can get stuff like that if i need it. its way too hot in fl to pull anything that takes time right now. i cant put a bracket for my new battery on without soaking a shirt right now. it would suck pulling some shifter cables right now lol.
i no this doesnt have alot to do with the thread but i never miss an opertunity to bash florida
3x CFR SCCA autocross champion with a 95 SL2 & 98 SC2
Currently own a 02 L200 with no plans to mod.
xupthree60 is offline   Reply With Quote
Old 10-03-2006, 10:03 AM   #4
Psywar
Psywar is on a distinguished road
1999 SW2
theirs actually a replacement bushing you can buy, to replace that.
They sell them on ebay..
They have a Nylon one, and a Steel one.
I would go with the steel one myself..
Steel one:
http://cgi.ebay.com/Saturn-Stick-Shi...QQcmdZViewItem
Nylon one:
http://cgi.ebay.com/Improved-Saturn-...QQcmdZViewItem
One of these will fix up your problem..
from what I have read you can even use a few zipties for now to hold it inplace.. (Not a perminate fix though)
but to get you from short distances and back.
-Chuck
Psywar is offline   Reply With Quote
Old 10-03-2006, 10:28 AM   #5
WingsOfSaturn
WingsOfSaturn will become famous soon enoughWingsOfSaturn will become famous soon enough
WingsOfSaturn's Avatar
Also Advance Auto sells 5 bushings for $10. And they do work.
Shift Linkage Bushing:
Wiper Linkage Bushings (for Toyota Camry 2001-97, Corolla 2002-98)
http://www.partsamerica.com/ProductD...rtnumber=49448
"When you stop to fill up on oil, don't forget to check the gas"
98 SL2 MT 213K+ Daily Driver 38+ mpg
97 SL2 AT 150K Original Owner
95 SL2 MT 220K+
My Saturns have BRASS ones!
WingsOfSaturn is offline   Reply With Quote
Old 10-03-2006, 08:23 PM   #6
Psywar
1999 SW2
+1
Forgot you could do that!
Good Call!
Saturn manual shifter cables sucks! Shifter eyelet came off turbobuick33 S-Series Tech 22 05-28-2007 04:10 PM
Saturn Vue shifter knob Jopo528 Vue General 8 05-22-2007 03:50 PM
98 Saturn SL Shifter cable replacement tfreilly S-Series Tech 7 03-16-2006 02:23 PM
98 Saturn SL Shifter cable tfreilly L-Series General 0 01-23-2006 01:57 PM
Saturn ION shifter Knobs ionize Ion Tech 3 10-25-2005 06:00 PM
