Old 07-09-2006, 02:29 PM   #1
beasticeman
beasticeman is on a distinguished road
Question oxygen censer problem
i have a 1996 SC2 and all i would like to know is. How i can tell if my Oxygen censer is bad. and if it is bad can it cause stalling or spottering. Wat does it cause?
beasticeman is offline   Reply With Quote
Old 07-09-2006, 03:32 PM   #2
M.Nguyen
M.Nguyen is on a distinguished road
M.Nguyen's Avatar
1993 SL2
Default Re: oxygen censer problem
If it's bad, you'll get a service engine soon light.
And it can cause sputtering, and stalling, yes.
It can also cause bad gasmileage, poor fuel economy, slow accelerationg, loopy idle, and tons of other stuff.
M.Nguyen is offline   Reply With Quote
Old 07-09-2006, 06:22 PM   #3
eljefino
eljefino will become famous soon enough
eljefino's Avatar
1995 SW1
2000 SL1
One rednecky way is to unplug it and throw your car into open loop mode. If it improves how it runs that generally (but not specifically) indicates your o2 sensor as having issues. You WILL throw a code when you do this but the code should go away after you plug it back in.
A better way is to plug a scan computer in and see how quickly its voltage varies. Actually you might be able to do this with a digital voltmeter, should swing between .1 and .9 volts. Only thing is most digital voltmeters update their displays twice a second and the o2 can swing faster than that.
Stalling and sputtering can be anything, of course... a symptom as specific as a sniffle or headache which could be caused by 100 things.
eljefino is offline   Reply With Quote
Old 07-09-2006, 09:38 PM   #4
PlasticCarsRock
PlasticCarsRock's Avatar
1995 SL2
Originally Posted by beasticeman
Oxygen censer
It's actually an oxygen sensor.
Don't get upset at me-it's constructive criticism (I spell things wrong all the time too-if people point it out-I can learn from my mistakes).
High compression build: .033" shaved/ported head, flat-faced valves; gen3 rods, pistons, tie-plate; OE header, custom CAI, SDA street cams with adjustable sprockets, WBO2, SAFCII, LSD. ASE A1-A8+L1
Old 07-09-2006, 09:42 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
If one or both of them are bad, you would get a "Service Engine Soon" light and a code would be stored in the PCM. Having a bad front oxygen sensor could cause drivable problems. a bad rear heated oxygen sensor would just make the light come on but not effect fuel control.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 07-10-2006, 04:49 AM   #6
eljefino
eljefino's Avatar
1995 SW1
2000 SL1
if an o2 swings slowly it can cause noticeable drivability issues but might not light a CEL until it completely dies. Rather like the CTS failure mode, if it generates believable info to the computer.
Old 12-05-2006, 03:48 AM   #7
strongboy2005
strongboy2005 is on a distinguished road
Does unplugging the sensor throw it into open loop mode automatically or is this something you have to "do"?
strongboy2005 is offline   Reply With Quote
Old 12-05-2006, 01:35 PM   #8
eljefino
eljefino's Avatar
1995 SW1
2000 SL1
Open loop will be automatic, as the (front) oxygen sensor is the only thing that "sees" how rich/lean things are after combustion. In fact every time you start the car it runs in open loop until it warms up enough for the sensor to start sending data. If it doesn't eventually wind up with good o2 data it'll throw a code but keep trucking along in open loop.
Old 12-05-2006, 03:38 PM   #9
strongboy2005
So technically, if my O2 sensor was bad, then I could get a 1/4 mile time with my O2 sensor connected and one without and compare? If it's slower with the O2 sensor connected, then time for a new one?
Old 12-05-2006, 04:40 PM   #10
Cat Fuzz
Cat Fuzz is on a distinguished road
Cat Fuzz's Avatar
1992 SL2
You can check them with a volt meter, but it can't be no dimestore special or Harbor Freight volt meter. I'm lucky enough to have a very nice Fluke 179 that I can test with but Fluke meters are expensive. Mine cost almost $300. An even better test tool would be to use an oscilloscope. You can literally see the voltage swing and measure it more precisely.
03 GMC Envoy XL
99 Isuzu Rodeo V-6, 4WD, Rebuilt 3.2L with 3.5L internals
63 Mercury Comet Convertible
Cat Fuzz is offline   Reply With Quote
oxygen sensor ns087 S-Series Tech 29 02-17-2014 08:50 AM
? Oxygen Sensor biglump S-Series General 5 01-23-2009 11:03 PM
How can you tell if an O2 censer is bad? beasticeman S-Series General 2 07-14-2006 10:04 PM
Oxygen Sensor... saturngurl S-Series Tech 35 12-13-2005 09:18 PM
Oxygen Sensor 1993 Blue SL2 S-Series Tech 2 02-23-2002 05:55 PM
